This is a known issue with Maven 2.1.0. If you drop back down to 2.0.10 it should work ok.
-Justin
Patel, Ronak Avinash (US SSA) wrote:
Justin,
While running the parent pom through mvn, I get the following error:
There's some step missing or the pom at that location is corrupted??
E:\eclipse\workspace\Geoserver\src>mvn install -Prestconfig
[INFO] Scanning for projects...
[WARNING] Overriding profile: 'geosearch' (source: pom) with new
instance from s
ource: pom
[INFO]
[ERROR] BUILD FAILURE
[INFO]
[INFO] The projects in the reactor contain a cyclic reference: Edge
between 'Ver
tex{label='org.geoserver.maven:build-configs'}' and
'Vertex{label='org.geoserver
.maven:build-configs'}' introduces to cycle in the graph
ld-configs --> org.geoserver.maven:build-configs
[INFO]
[INFO]
[INFO] Total time: < 1 second
[INFO] Finished at: Mon Apr 20 14:32:01 PDT 2009
[INFO] Final Memory: 4M/8M
[INFO]
E:\eclipse\workspace\Geoserver\src>mvn --version
Apache Maven 2.1.0 (r755702; 2009-03-18 12:10:27-0700)
Java version: 1.6.0_13
Java home: E:\jdk1.6.0_13\jre
Default locale: en_US, platform encoding: Cp1252
OS name: "windows xp" version: "5.1" arch: "x86" Family: "windows"
E:\eclipse\workspace\Geoserver\src>-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Monday, April 20, 2009 1:20 PM
To: Patel, Ronak Avinash (US SSA)
Cc: geoserver-users@lists.sourceforge.net; Froumis, James A (US SSA)
Subject: Re: [Geoserver-users] REST Configuration APIPatel,
That would be great if you could help debug. The source is available
here:http://svn.codehaus.org/geoserver/branches/1.7.x/src/extension/restconfi
g/I am not sure if you are an eclipse user, but the easiest way to set up a debug environment:
1) svn co http://svn.codehaus.org/geoserver/branches/1.7.x/ gs-1.7.x
2) cd gs-1.7.x/src
3) mvn clean install -P restconfig
5) mvn eclipse:eclipse -P restconfigThen import the modules into eclipse. Starting geoserver is then as simple as running Start.java in the web module.
More descriptive (but a little out of date) documents available here:
http://geoserver.org/display/GEOSDOC/2+Maven+Quickstart
http://geoserver.org/display/GEOSDOC/3+Eclipse+Quickstart-Justin
Justin,
I reported the problem to JIRA.
Would it be possible for me to look at the source code and help debug
the problem?Where can I find the source for the plugin?
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Tuesday, April 14, 2009 12:24 PM
Subject: Re: [Geoserver-users] REST Configuration APIOk, I was able to replicate the issue. Can you file a bug report in
jira?Patel, Ronak Avinash (US SSA) wrote:
Justin,
It seemed that it created the image the first time, but when I tried
to
upload the same image again, it barfed.
6600 [main] INFO /geoserver - Initializing WebApplicationContext for
Struts ActionServlet 'action', module ''
6629 [main] INFO org.mortbay.log - Opened
/opt/geoserver-1.7.3/logs/2009_04_14.request.log
6640 [main] INFO org.mortbay.log - Started
SelectChannelConnector@anonymised.com:8080
14 Apr 11:36:27 DEBUG [geoserver.filters] - filteringhttp://patel-dev.irad.net:8080/geoserver/rest/workspaces/leia11/coverage
stores/blah/file.geotiff
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - ConvertedURL
to lowercase, from:
'/rest/workspaces/leia11/coveragestores/blah/file.geotiff'; to:
'/rest/workspaces/leia11/coveragestores/blah/file.geotiff' and
httpMethod= PUT
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~
antPath= /** methodList= [Ljava.lang.String;@d0726d
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - method[0]:
GET
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidateis:
'/rest/workspaces/leia11/coveragestores/blah/file.geotiff'; antPath
is
/**; matchedPath=true; matchedMethods=false
antPath= /** methodList= [Ljava.lang.String;@1ccf342
POST
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - method[1]:
DELETE
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - method[2]:
PUT
is
/**; matchedPath=true; matchedMethods=true
13637 [btpool0-8] INFO /geoserver - Initializing SpringFrameworkServlet
'dispatcher'
14 Apr 11:36:27 DEBUG [gdal.erdasimg] - NITFFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.jp2ecw] - JP2ECWFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.ehdr] - EsriHdrFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.jp2mrisd] - JP2MrSIDFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gdal.dted] - DTEDFormatFactory is notavailaible.
14 Apr 11:36:27 DEBUG [gdal.mrsid] - MrSIDFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gce.arcgrid] - ArcGridFormatFactory is
availaible.
14 Apr 11:36:27 DEBUG [gdal.jp2k] - JP2KFormatFactory is notavailaible.
14 Apr 11:36:27 DEBUG [gdal.ecw] - ECWFormatFactory is not
availaible.
14 Apr 11:36:27 DEBUG [gce.arcgrid] - Creating a new ArcGriFormat.
14 Apr 11:36:27 INFO [catalog.rest] - PUT file, mimetype:image/geotiff
14 Apr 11:36:27 INFO [catalog.rest] - Auto-configuring coverage
store:
blah
14 Apr 11:36:27 INFO [geotools.factory] - Factory implementations for
category GridCoverageFactory:
org.geotools.coverage.grid.GridCoverageFactory
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
14 Apr 11:36:27 DEBUG [geoserver.global] - In method store DataDTO
14 Apr 11:36:27 DEBUG [geoserver.global] - In method storeFormat
14 Apr 11:36:27 DEBUG [geoserver.global] - In method storeCoverages
14 Apr 11:36:28 DEBUG [geoserver.global] - In method storeCoverageERROR HERE
14 Apr 11:36:46 DEBUG [geoserver.filters] - filtering
to lowercase, from:
httpMethod= PUT
GET
is
POST
DELETE
PUT
is
14 Apr 11:36:46 DEBUG [gdal.erdasimg] - NITFFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.jp2ecw] - JP2ECWFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.ehdr] - EsriHdrFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.jp2mrisd] - JP2MrSIDFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gdal.dted] - DTEDFormatFactory is notavailaible.
14 Apr 11:36:46 DEBUG [gdal.mrsid] - MrSIDFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gce.arcgrid] - ArcGridFormatFactory is
availaible.
14 Apr 11:36:46 DEBUG [gdal.jp2k] - JP2KFormatFactory is notavailaible.
14 Apr 11:36:46 DEBUG [gdal.ecw] - ECWFormatFactory is not
availaible.
14 Apr 11:36:46 DEBUG [gce.arcgrid] - Creating a new ArcGriFormat.
14 Apr 11:36:46 INFO [catalog.rest] - PUT file, mimetype:image/geotiff
14 Apr 11:36:46 INFO [catalog.rest] - Using existing coverage store:
blah
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
availaible.
14 Apr 11:36:46 ERROR [geoserver.rest] - Error auto-configuring
coverage:java.lang.NullPointerException
14 Apr 11:36:46 DEBUG [geoserver.rest] -
org.geoserver.rest.RestletException: java.lang.RuntimeException:
atorg.geoserver.catalog.rest.CoverageStoreFileResource.handlePut(CoverageS
toreFileResource.java:165)
at org.restlet.Finder.handle(Finder.java:298)
atorg.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.ja
va:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
atcom.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverte
r.java:129)
atorg.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.j
ava:79)
atorg.springframework.web.servlet.mvc.AbstractController.handleRequest(Abs
tractController.java:153)
atorg.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handl
e(SimpleControllerHandlerAdapter.java:48)
atorg.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherS
ervlet.java:875)
atorg.springframework.web.servlet.DispatcherServlet.doService(DispatcherSe
rvlet.java:809)
atorg.springframework.web.servlet.FrameworkServlet.processRequest(Framewor
kServlet.java:571)
atorg.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.
java:521)
atjavax.servlet.http.HttpServlet.service(HttpServlet.java:730)
at
javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHan
dler.java:1093)
atorg.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharac
terEncodingFilter.java:108)
atorg.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHan
dler.java:1084)
atorg.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(Filt
erChainProxy.java:264)
atorg.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterS
ecurityInterceptor.java:107)
atorg.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(Filte
rSecurityInterceptor.java:72)
erChainProxy.java:274)
atorg.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTransl
ationFilter.java:110)
atorg.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter
(AnonymousProcessingFilter.java:125)
atorg.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProce
ssingFilter.java:178)
atorg.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(H
ttpSessionContextIntegrationFilter.java:229)
atorg.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:1
48)
atorg.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java
:98)
dler.java:1084)
at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
dler.java:1084)
atorg.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.jav
a:163)
dler.java:1084)
atorg.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at
dler.java:1084)
atorg.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:2
16)
atorg.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
atorg.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandler
Collection.java:206)
atorg.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.jav
a:114)
atorg.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
atorg.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.j
ava:842)
atorg.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
at
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
atorg.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:
395)
atorg.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.ja
va:450)
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
at
org.geoserver.catalog.CatalogBuilder.update(CatalogBuilder.java:232)
atorg.geoserver.catalog.CatalogBuilder.updateCoverage(CatalogBuilder.java:
155)
toreFileResource.java:132)
... 56 more
Caused by: java.lang.NullPointerException
at sun.reflect.NativeMethodAccessorImpl.invoke0(NativeMethod)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.jav
a:39)
atsun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessor
Impl.java:25)
atorg.geoserver.catalog.CatalogBuilder.updateMapProperty(CatalogBuilder.ja
va:251)
at
org.geoserver.catalog.CatalogBuilder.update(CatalogBuilder.java:224)
... 58 more-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Tuesday, April 14, 2009 11:29 AM
Subject: Re: [Geoserver-users] REST Configuration APIBoth, they both contain a few related bug fixes not in the 1.7.3
release.Patel, Ronak Avinash (US SSA) wrote:
The nightly build of geoserver? Or the plugin?
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Tuesday, April 14, 2009 11:26 AM
Subject: Re: [Geoserver-users] REST Configuration APIOk, this fix went in after 1.7.3. Is there any chance you could try
it
out with the latest nightly build? That will at least give us the exception that is occurring. Sorry for the inconvenience.
-Justin
I downloaded the latest stable build 1.7.3a. I just downloaded that
and
the REST plugin from geoserver.org today.
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Tuesday, April 14, 2009 11:24 AM
Cc: geoserver-users@lists.sourceforge.net; Froumis, James A (USSSA)
Hmmm... I am still not seeing the exception in the logs. Come to
think
of it I think i added the logging statement in my latest patch to
fix
the related issue. What build are you running?
Hi Justin,
I set the logs to verbose like you said and I get the following
error:
14 Apr 11:13:33 DEBUG [geoserver.filters] - filtering
[security.RESTfulPathBasedFilterInvocationDefinitionMap] -Converted
URL
to lowercase, from:
httpMethod= PUT
[security.RESTfulPathBasedFilterInvocationDefinitionMap] -~~~~~~~~~~
antPath= /** methodList= [Ljava.lang.String;@893918
[security.RESTfulPathBasedFilterInvocationDefinitionMap] -method[0]:
GET
[security.RESTfulPathBasedFilterInvocationDefinitionMap] -Candidate
is:
antPath
is
antPath= /** methodList= [Ljava.lang.String;@327236
POST
[security.RESTfulPathBasedFilterInvocationDefinitionMap] -method[1]:
DELETE
[security.RESTfulPathBasedFilterInvocationDefinitionMap] -method[2]:
PUT
is:
antPath
is
14 Apr 11:13:33 DEBUG [gce.arcgrid] - ArcGridFormatFactory is
availaible.
14 Apr 11:13:33 DEBUG [gce.arcgrid] - Creating a new ArcGriFormat.
14 Apr 11:13:33 INFO [catalog.rest] - PUT file, mimetype:image/geotiff
14 Apr 11:13:33 INFO [catalog.rest] - Using existing coverage
store:
blah
availaible.
14 Apr 11:13:33 ERROR [geoserver.rest] - Error auto-configuring
coverage:java.lang.NullPointerExceptionLike you said, I blow away the contents of the
/opt/geoserver-1.7.3/data_dir/data/coveragestorename to get rid ofmy
geotiff file.
I see that the HTTP PUT does indeed upload my file to geoserver
fine.
The problem seems to be with processing the geotiff file after a
successfull upload.Hopefully this is helpful.
Ronak Patel
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Tuesday, April 14, 2009 10:43 AM
Hi Patel,
Can you log into the admin console and turn on verbose logging.
Config -> Server and change logging to GEOSERVER_DEVELOPER. And
then
try
again including the stack trace from the error log.
Also, when files are uploaded they get put into the "data"
directory
under neath GEOSERVER_DATA_DIR, you may want to try clearing out
the
appropriate sub directories to ensure a "fresh" start. Which
reminds
me
I fixed an issue recently with files not being able to overwrite existing files, that might be coming into play here.
-Justin
Justin,
By the way, I am actually PUTing the image to the server and NOT
POSTing.I keep getting this error when I try to upload a png or jpg:
14 Apr 10:00:08 INFO [catalog.rest] - PUT file, mimetype:
image/jpeg
14 Apr 10:00:08 INFO [catalog.rest] - Using existing coverage
store:
blah
14 Apr 10:00:08 ERROR [geoserver.rest] - Error auto-configuring
coverage:Unsupported file format
14 Apr 10:00:22 INFO [catalog.rest] - PUT file, mimetype:image/png
14 Apr 10:00:22 INFO [catalog.rest] - Using existing coverage
store:
blah
14 Apr 10:00:22 ERROR [geoserver.rest] - Error auto-configuring
coverage:Unsupported file formatWhen I try to upload a GeoTiff, I always get the following error:
14 Apr 10:03:49 INFO [catalog.rest] - PUT file, mimetype:
image/tif
14 Apr 10:03:49 INFO [catalog.rest] - Using existing coverage
store:
blah
14 Apr 10:03:49 ERROR [geoserver.rest] - Error auto-configuring
coverage:java.lang.NullPointerExceptionI hope that helps in debugging the situation.
Thanks a million!!
Ronak Patel
From: Patel, Ronak Avinash (US SSA) Sent: Tuesday, April 14, 2009 9:50 AM
To: 'Justin Deoliveira'
Subject: RE: [Geoserver-users] REST Configuration API
Justin,
I desperately tried all day yesterday to try to POST a coverage
and
get
Geoserver to accept my image (a GeoTiff).
I am POSTing to a CoverageStore and Workspace that I create using
the
REST API.
I am POSTing the following:
URL:
/geoserver/rest/workspaces/testWorkspace/coveragestores/testStore/file.g
eotiff
POST ContentType image/tif and the POST content is the file.
I noticed that if I set the configure=none&coverageName=test
flags
in
the URL, then the file is ingested by Geoserver without
complaining.
When I don't set these cgi parameters, things fail and complain.
Why does this happen?
Also, do I have to create a layer to host the image in the WMS?
Or
is
this done automatically?
Thanks a million!!
Ronak Patel
Justin Deoliveira
OpenGeo - http://opengeo.org
