When we see an error such as this, it is because either a) we forgot a jar file during a copy process, or b) there are more than one version of the jar file available to the application and the wrong one was loaded by the class loader.
Check your WEB-INF/lib for the expected jar. If it is missing, add it. If there are multiple versions of the same jar, rename the oldest version (usually the correct route) and restart the service.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
![Description: Description: Description: cid:image001.png@anonymised.com]()
From: pablo zader [mailto:pzader@anonymised.com84…]
Sent: Saturday, September 27, 2014 12:22 AM
Subject: Re: [Geoserver-users] rest/imports 405 Method Not Allowed
Update:
I notice that I needed to install the import plugin, which had assumed that was installed. I download the plugin from here (http://sourceforge.net/projects/geoserver/files/GeoServer/2.5.2/) and add it to geoserver.
Now another problem happens with LayerUploadPanel plugin:
POST http://localhost:9080/geoserver/rest/imports/0/tasks?expand=all 500 (Server Error)
and the error complete is:
Estado HTTP 500 - Handler processing failed; nested exception is java.lang.NoClassDefFoundError: org/apache/commons/vfs/FileSelector
type Informe de Excepción
mensaje Handler processing failed; nested exception is java.lang.NoClassDefFoundError: org/apache/commons/vfs/FileSelector
descripción El servidor encontró un error interno que hizo que no pudiera rellenar este requerimiento.
excepción
org.springframework.web.util.NestedServletException: Handler processing failed; nested exception is java.lang.NoClassDefFoundError: org/apache/commons/vfs/FileSelector
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:972)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
javax.servlet.http.HttpServlet.service(HttpServlet.java:646)
javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
causa raíz
org.geoserver.importer.Directory.unpack(Directory.java:92)
org.geoserver.importer.Directory.accept(Directory.java:393)
org.geoserver.importer.rest.TaskResource.handleMultiPartFormUpload(TaskResource.java:176)
org.geoserver.importer.rest.TaskResource.handlePost(TaskResource.java:88)
org.restlet.Finder.handle(Finder.java:296)
org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
org.restlet.Filter.doHandle(Filter.java:105)
org.restlet.Filter.handle(Filter.java:134)
org.restlet.Router.handle(Router.java:444)
org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
causa raíz
java.lang.ClassNotFoundException: org.apache.commons.vfs.FileSelector
org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1720)
org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1571)
nota La traza completa de la causa de este error se encuentra en los archivos de diario de Apache Tomcat/7.0.53.
I can not figure out where this error.
Thanks in advanced
2014-09-25 4:48 GMT-03:00 pablo zader <pzader@anonymised.com>:
Hi list
I have problems when I want to load a tiff or shape by the plugin LayerUploadPanel.js of GeoExplorer.
The error here:
POST http://localhost:9080/geoserver/rest/imports 405 (Method Not Allowed)
The code in LayerUploadPanel.js
Ext.Ajax.request({
url: this.getUploadUrl(),
method: “POST”,
jsonData: jsonData,
success: function(response) {
this._import = response.getResponseHeader(“Location”);
this.optionsFieldset.expand();
form.submit({
url: this._import + “/tasks?expand=all”,
waitMsg: this.waitMsgText,
waitMsgTarget: true,
reset: true,
scope: this
I am using Geoserver 2.5.2.
But in Geoserver 2.4 SNAPSHOT work well!!1
How I can solve this problem? It is a problem of geoserver, but there will be some way to solve client side programmatically.
Thanks
Pablo J. Zader
Lic. en Cs. de la Computación
CONAE
pablo.zader@anonymised.com
"Los Grandes Hombres hablan sobre ideas…
Los Hombres Promedio hablan sobre cosas…
Los Hombres Pequeños hablan… de otros Hombres.
del libro Matemática estas ahi? A. Paenza "
