I noticed in the MapPreview window that any layers I created using the
REST Config API has GeoRSS disabled.
Is there any way to turn GeoRSS capability on for these layers? I didn't
notice anything in the REST API that allows for that...
Is this a planned improvement?
Ronak
Hi Ronak,
Just to confirm these are vector based layers you are adding? If they are then this is probably a bug. I will try to see if I can reproduce.
-Justin
Patel, Ronak Avinash (US SSA) wrote:
Ronak
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
