Justin,
I am adding raster based layers...GeoTiffs with PNG images.
Ronak Patel
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Tuesday, May 05, 2009 6:08 PM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: [Geoserver-users] REST Layers and GeoRSS
Hi Ronak,
Just to confirm these are vector based layers you are adding? If they
are then this is probably a bug. I will try to see if I can reproduce.
-Justin
Patel, Ronak Avinash (US SSA) wrote:
I noticed in the MapPreview window that any layers I created using the
REST Config API has GeoRSS disabled.Is there any way to turn GeoRSS capability on for these layers? I
didn't
notice anything in the REST API that allows for that...
Is this a planned improvement?
Ronak
The NEW KODAK i700 Series Scanners deliver under ANY circumstances!
Your
production scanning environment may not be a perfect world - but
thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW
KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
