Hi Anton,
while removeSchema has indeed been added to the GeoTools API,
I don’t believe it has been used in the REST API.
That seems to explain why what you’re trying to do does not work.
I believe the code would have to be modified here, dropping and re-creating
the schema, assuming source and target schema are not the same,
and the target store supports dropping to start with:
https://github.com/geoserver/geoserver/blob/master/src/restconfig/src/main/java/org/geoserver/catalog/rest/DataStoreFileResource.java#L368
On Fri, Feb 26, 2016 at 3:56 PM, Anton Bakker <anton.bakker@anonymised.com> wrote:
When reuploading a shapefile with a changed schema (additional attribute) to a postgis datastore like this:
/rest/workspaces/cite/datastores/postgis/file.shp?update=overwrite&charset=UTF-8
I receive a 201 created response, but the PostGIS table is not changed. The new attribute nor the additional records are added to the PostGIS table. The response suggests that the data has been changed in the PostGIS table.
This issue has been addressed earlier in the user email list, but I could not find anything else on it. Any suggestions or comments are more then welcome.
Thanks!
Anton Bakker, Software Engineer
www.geocat.net | anton.bakker@anonymised.com
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
