[Geoserver-users] REST security
Hi list.
I have an issue with Rest security in latest geoserver 2.3.5 (also in 2.3.4) I use j2ee authentication filter for authorization in our JOSSO system. Authorization is proceeding normally and everything is working as it should, but when I try to create a workspace via a REST receive the following error
2013-09-03 08:55:07,145 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: ‘/rest/workspaces’; to: ‘/rest/workspaces’ and httpMethod= POST
2013-09-03 08:55:07,145 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
2013-09-03 08:55:07,145 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/rest/workspaces’; antPath is /; matchedPath=true; matchedMethods=false
methodList= [POST, DELETE, PUT]
2013-09-03 08:55:07,145 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/rest/workspaces’; antPath is /**; matchedPath=true; matchedMethods=true
2013-09-03 08:55:07,145 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning RIHMI-WDC.RCITU:GIS:ADMIN
2013-09-03 08:55:07,146 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces]
2013-09-03 08:55:07,149 DEBUG [org.geoserver] - Thread 151 locking in mode WRITE
2013-09-03 08:55:07,149 DEBUG [org.geoserver] - Thread 151 got the lock in mode WRITE
2013-09-03 08:55:07,181 DEBUG [org.geoserver] - Thread 151 releasing the lock in mode WRITE
2013-09-03 08:55:07,182 ERROR [geoserver.rest] -
com.thoughtworks.xstream.io.StreamException: : input contained no data
at com.thoughtworks.xstream.io.xml.XppReader.pullNextEvent(XppReader.java:126)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.readRealEvent(AbstractPullReader.java:148)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.readEvent(AbstractPullReader.java:141)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.move(AbstractPullReader.java:118)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.moveDown(AbstractPullReader.java:103)
at com.thoughtworks.xstream.io.xml.XppReader.(XppReader.java:63)
at com.thoughtworks.xstream.io.xml.AbstractXppDriver.createReader(AbstractXppDriver.java:54)
at com.thoughtworks.xstream.io.xml.AbstractXppDriver.createReader(AbstractXppDriver.java:65)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:922)
at org.geoserver.config.util.XStreamPersister.load(XStreamPersister.java:549)
at org.geoserver.catalog.rest.AbstractCatalogResource$1.read(AbstractCatalogResource.java:50)
at org.geoserver.rest.format.StreamDataFormat.toObject(StreamDataFormat.java:33)
at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:117)
at org.restlet.Finder.handle(Finder.java:296)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.geoserver.security.filter.GeoServerPreAuthenticationFilter.doFilter(GeoServerPreAuthenticationFilter.java:74)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at com.googlecode.psiprobe.Tomcat70AgentValve.invoke(Tomcat70AgentValve.java:38)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.josso.tc70.agent.SSOAgentValve.invoke(SSOAgentValve.java:672)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.ha.session.JvmRouteBinderValve.invoke(JvmRouteBinderValve.java:219)
at org.apache.catalina.ha.tcp.ReplicationValve.invoke(ReplicationValve.java:335)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.EOFException: input contained no data
at org.xmlpull.mxp1.MXParser.fillBuf(MXParser.java:2983)
at org.xmlpull.mxp1.MXParser.more(MXParser.java:3026)
at org.xmlpull.mxp1.MXParser.parseProlog(MXParser.java:1410)
at org.xmlpull.mxp1.MXParser.nextImpl(MXParser.java:1395)
at org.xmlpull.mxp1.MXParser.next(MXParser.java:1093)
at com.thoughtworks.xstream.io.xml.XppReader.pullNextEvent(XppReader.java:109)
… 104 more
Creating a workspace with a basic authentication filter is working fine…
My curl command
curl -b /tmp/geoserver.txt -XPOST -H “Content-type: text/xml” -d “new” http://localhost:8081/resources/rest/workspaces
/tmp/geoserver.txt is a cookie file received from the JOSSO.
Java 7.0_25 and Tomcat 7.0.42 on Linux
Please help me what is the problem?
Cheers, Dmitriy
Only to be sure, did you put your j2ee filter on the rest queue (ant pattern /rest/**)
Christian
On Wed, Sep 4, 2013 at 12:13 PM, Dmitriy Tyugaev <dtyugaev@anonymised.com> wrote:
Hi list.
… 104 more
My curl command
Cheers, Dmitriy
Learn the latest–Visual Studio 2012, SharePoint 2013, SQL 2012, more!
Discover the easy way to master current and previous Microsoft technologies
and advance your career. Get an incredible 1,500+ hours of step-by-step
tutorial videos with LearnDevNow. Subscribe today and save!
http://pubads.g.doubleclick.net/gampad/clk?id=58040911&iu=/4140/ostg.clktrk
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Yes Christian, j2ee filter is in the rest filter chain settings. In any case, I found a solution by changing the header Content-type to application/xml instead of text/xml. Now everything works.
Dmitriy
On Wed, Sep 4, 2013 at 2:42 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Christian
Hi list.
… 104 more
My curl command
Cheers, Dmitriy
