[Geoserver-users] Restrict access to admin controls based on ip address
hello
I found the answer to this question in the following archived post, https://sourceforge.net/p/geoserver/mailman/message/30830992/, and it worked insofar as the access to the admin controls was successfully restricted. However, the webmap is now not showing any data if I am not accessing it from the nominated ip address.
Has anybody else come up against this?
regards
shawn
Hi Shawn,
It looks like that solution is using filtering at the container level (i.e., Tomcat). You might be able to change the to be /web/* instead of . That should prevent access to the /web/ pages while leaving access to /ows/,/wfs/, etc. endpoints.
Jim
ยทยทยท
On 06/07/2016 05:12 PM, Shawn Stanley wrote:
hello
regards
shawn
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. [https://ad.doubleclick.net/ddm/clk/305295220;132659582;e](https://ad.doubleclick.net/ddm/clk/305295220;132659582;e)
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
thanks very much Jim
that worked perfectly
Date: 07/06/2016 18:01
Subject: Re: [Geoserver-users] Restrict access to admin controls based on ip address
Hi Shawn,
Jim
hello
regards
shawn
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e_______________________________________________
