On Thu, Nov 5, 2015 at 6:30 PM, Douville, Michelle R GCPE:EX <
Michelle.Douville@anonymised.com> wrote:
Hi All,
I would like to restrict output format types in geoserver (2.6), WMS and
WFS.
I could restrict formats using apache HTTPD, but I was hoping to also not
have them listed in the getcapabilities as well.
Has Anyone tried to do this?
All output formats are pluggable, so there are multiple ways to remove
them... by writing code...
The idea to make them actually configurable from the UI has been on the
table for a long time, but nobody sponsored that
work so far. If you are interested in getting this functionality, here is a
guide for you:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
