I suspect the following cannot be expressed in a single WFS request, not sure if there is a GeoServer extension that supports this?
“Give me the feature of type X that has the maximum value for property Y among all features of type X”
Alex
Alex Milanovic ha scritto:
"Give me the feature of type X that has the maximum value for property Y among all features of type X"
Indeed it cannot be expressed as a single WFS request, it could probably
be part of a WPS request instead, but our WPS is only a prototype
for the moment.
Right now we don't have any way to support such a request, sorry.
Andrea Aime
OpenGeo - http://opengeo.org
Ah, btw, a cheap way to get that could be to create a view that resolves that request for all x values.
create view myPublicGeoServerType as select *
from table t1
where t1.id = (select t2.id
from table t2
where t2.x = t1.x
and y = (select max(y) from table t3 where t3.x = t2.x))
And the thru wfs you just add the x = somevalue predicate,
the sql optimizer should be smart enough to recognize the
overall structure of the query and optimize it so that
only the records with x = somevalue are scanned.
Just a thought
Andrea Aime
Wonder, if property Y is of a numeric type, shouldn't a sortby Y descending and maxFeatures=1 do the trick?
2c.-
Gabriel
for the moment.
Oh, you're right indeed, good thinking.
Andrea Aime
Both good ideas, thanks.
Alex
Wonder, if property Y is of a numeric type, shouldn’t a sortby Y descending and maxFeatures=1 do the trick?
Oh, you’re right indeed, good thinking.
Andrea Aime
