Hi, Hi may street map is in a postgis table. The srid is 26331. I used this query http://localhost:13218/geoserver/wms?bbox=522030.875,713514.9375,548229.5,727000.6875&Format=image/png&request=GetMap&layers=topp:lagos_roads&width=550&height=250&srs=EPSG:26331&featureid=lagos_roads.1 and it gave me the following error: Caused by: org.geotools.data.DataSourceException: Error Performing SQL query: SELECT “gid”, encode(asBinary(force_2d(“the_geom”),‘XDR’),‘base64’) FROM “public”.“lagos_roads” WHERE ((“gid” = ‘1’) AND “the_geom” && GeometryFromText(‘POLYGON ((521078.19772727275 712436.0775, 521078.19772727275 728079.5475, 549182.1772727272 728079.5475, 549182.1772727272 712436.0775, 521078.19772727275 712436.0775))’, 4326)) at org.geotools.data.jdbc.JDBC1DataStore.executeQuery(JDBC1DataStore.java:937) at org.geotools.data.jdbc.JDBC1DataStore.getFeatureReader(JDBC1DataStore.java:649) at org.geotools.data.jdbc.JDBCFeatureCollection.reader(JDBCFeatureCollection.java:88) at org.geotools.data.store.DataFeatureCollection.openIterator(DataFeatureCollection.java:229) at org.geotools.data.store.DataFeatureCollection.iterator(DataFeatureCollection.java:199) at org.geotools.data.store.DataFeatureCollection.features(DataFeatureCollection.java:188) at org.geotools.data.crs.ForceCoordinateSystemFeatureResults.openIterator(ForceCoordinateSystemFeatureResults.java:93) at org.geotools.feature.collection.AbstractFeatureCollection.iterator(AbstractFeatureCollection.java:332) at org.geotools.renderer.lite.StreamingRenderer.drawOptimized(StreamingRenderer.java:1747) … 75 more Caused by: org.postgresql.util.PSQLException: ERROR: Operation on two geometries with different SRIDs at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:1525) at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1309) at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:188) at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:452) at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:340) at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:239) at org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208) at org.geotools.data.jdbc.JDBC1DataStore.executeQuery(JDBC1DataStore.java:926) … 83 more A closer look at the query sent to postgis will reveal that the srid 4326 was used instead of 26331. I don’t know how this happened. Thanks, Roman. |
Hi Roman,
It seems geoserver thinks the native data is in 4326. A couple of quetsions:
What is the srid specified on the table? Is there a geometry_columns entry for it.
What srid did you specify on the feature type editor page? And which SRS handling mode?
-Justin
Roman Isitua wrote:
Caused by: org.geotools.data.DataSourceException: Error Performing SQL query: SELECT "gid", encode(asBinary(force_2d("the_geom"),'XDR'),'base64') FROM "public"."lagos_roads" WHERE (("gid" = '1') AND "the_geom" && GeometryFromText('POLYGON ((521078.19772727275 712436.0775, 521078.19772727275 728079.5475, 549182.1772727272 728079.5475, 549182.1772727272 712436.0775, 521078.19772727275 712436.0775))', 4326))
... 75 more
... 83 moreA closer look at the query sent to postgis will reveal that the srid 4326 was used instead of 26331. I don't know how this happened.
Roman.
Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
is a gathering of tech-side developers & brand creativity professionals. Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, & iPhoneDevCamp asthey present alongside digital heavyweights like Barbarian
Group, R/GA, & Big Spaceship. http://www.creativitycat.com------------------------------------------------------------------------
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
