Hi, Sorry but i don’t undertand what u mean by change geometry_columns ? Is this a setting in geoserver or postgis ? where can it be changed ? the geometry column in my postgis table is named " the_geom ". Thanks, Roman. — On Mon, 5/25/09, Andrea Aime aaime@anonymised.com wrote: > From: Andrea Aime aaime@anonymised.com > Subject: Re: [Geoserver-users] retrieving wms map from a postgis table with srid 26331 > To: “Roman Isitua” romanisitua@anonymised.com > Cc: “Justin Deoliveira” jdeolive@anonymised.com, “geoserver users” geoserver-users@anonymised.com.net > Date: Monday, May 25, 2009, 1:40 AM > > Roman Isitua ha scritto: > > Justin, > > > > The answers to your question are as follows: > > > > - The srid of my table is 26331. > > - There is a geometry column for it. The column name is (the_geom). > > - The srid I specified on the feature type editor was 26331. > > - The srs handling mode was " Force declared SRS (native will be ignored) ". (by the way, whats the difference between the different srs handling modes ?) > > GeoServer has to use a double standard when dealing with postgis. > What you set in the GeoServer UI influences the results you get out > of the OGC services. > What you set in the geometry_columns table influences what SRS will > be used for queries instead, the datastore (rightfully imho) assumes > you setup postgis properly and that your geometries srid and > whatever you declared in geometry_columns is consistent. > In your case I guess you have 4326 in geometry columns by 26331 in > the geometries stored in your database. Change geometry_columns, > force a reload in GeoServer and you should be good. > > Cheers > Andrea > > – Andrea Aime > OpenGeo - http://opengeo.org > Expert service straight from the developers. |
Sorry but i don't undertand what u mean by change geometry_columns ? Is this a setting in geoserver or postgis ? where can it be changed ? the geometry column in my postgis table is named " the_geom ".
The geometry_columns table is a postgis geographic metadata table.
You need it to be properly setup for the datastore to work.
http://www.postgis.org/documentation/manual-1.3/ch04.html#id2571510
Andrea Aime
