On Tue, Aug 2, 2016 at 6:48 AM, Farook M <farookrceg@anonymised.com> wrote:
Hi Andrea,
Thanks for the response. If the returning is feature is 4, will the WPS
return 1 extent for all the 4 returning features instead of 4 individual
extents?
One extent only. E.g., this is an example request against the local
tiger:roads layer:
<?xml version="1.0" encoding="UTF-8"?><wps:Execute version="1.0.0"
service="WPS" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="
http://www.opengis.net/wps/1.0.0" xmlns:wfs="http://www.opengis.net/wfs"
xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="
http://www.opengis.net/ows/1.1" xmlns:gml="http://www.opengis.net/gml"
xmlns:ogc="http://www.opengis.net/ogc" xmlns:wcs="
http://www.opengis.net/wcs/1.1.1" xmlns:xlink="http://www.w3.org/1999/xlink"
xsi:schemaLocation="http://www.opengis.net/wps/1.0.0
http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">
<ows:Identifier>gs:Bounds</ows:Identifier>
<wps:DataInputs>
<wps:Input>
<ows:Identifier>features</ows:Identifier>
<wps:Reference mimeType="text/xml" xlink:href="http://geoserver/wfs"
method="POST">
<wps:Body>
<wfs:GetFeature service="WFS" version="1.0.0" outputFormat="GML2"
xmlns:tiger="http://www.census.gov">
<wfs:Query typeName="tiger:tiger_roads"/>
</wfs:GetFeature>
</wps:Body>
</wps:Reference>
</wps:Input>
</wps:DataInputs>
<wps:ResponseForm>
<wps:RawDataOutput>
<ows:Identifier>bounds</ows:Identifier>
</wps:RawDataOutput>
</wps:ResponseForm>
</wps:Execute>
If I save it into a file in /tmp/bounds.xml and post it to the GeoSolutions
demo GeoServer like this:
curl -H "Content-type: text/xml" -d @/tmp/bounds.xml "
http://demo.geo-solutions.it/geoserver/ows"
then the response is a single bounding box for the entire layer:
<?xml version="1.0" encoding="UTF-8"?><ows:BoundingBox xmlns:xs="
http://www.w3.org/2001/XMLSchema" xmlns:ows="http://www.opengis.net/ows/1.1"
crs="EPSG:4326"><ows:LowerCorner>-74.02722
40.684221</ows:LowerCorner><ows:UpperCorner>-73.907005
40.878178</ows:UpperCorner></ows:BoundingBox>
You can modify the WFS request embedded in the WPS one (acting as the data
source) in order to
filter the features being used to compute the bbox
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
