[Geoserver-users] RPF Support in GeoServer
Does anyone know if GeoServer supports CADRG data as RPF. I tried to use
the NITF coverage format (from the GDAL Plugin) and load the A.TOC file into
the CoverageStore, but GeoServer throws an error because it believes there
should be image data in that file (which there isn't because the file just
describes the data underneath it's directory structure). I know the NITF
support works on my server because I was able to load a sample NITF file
(one that actually has image data in it). If anyone has found a way to load
the data in RPF format I would greatly appreciate any help.
Rick
P.S. Here is the stack trace when I try to load the A.TOC file. Probably
won't help but thought I would throw it out there if any found it useful.
Warning 1: The file /home/mcadamsrb/temp/testdata/cdrgxgncjncs_9/rpf/A.TOC
appears to be an NITF file, but no image
blocks were found on it.
ERROR 5: GDALDataset::GetRasterBand(1) - Illegal band #
08 Jan 16:10:35 WARN [action.RequestProcessor] - Unhandled Exception thrown:
class java.lang.NullPointerException
21518876 [btpool0-4] ERROR org.mortbay.log - Nested in
javax.servlet.ServletException: java.lang.NullPointerException:
  at
it.geosolutions.imageio.gdalframework.GDALCommonIIOImageMetadata.setMembers(GDALCommonIIOImageMetadata.java:349)
  at
it.geosolutions.imageio.gdalframework.GDALCommonIIOImageMetadata.<init>(GDALCommonIIOImageMetadata.java:264)
  at
it.geosolutions.imageio.gdalframework.GDALCommonIIOImageMetadata.<init>(GDALCommonIIOImageMetadata.java:288)
  at
it.geosolutions.imageio.gdalframework.GDALCommonIIOImageMetadata.<init>(GDALCommonIIOImageMetadata.java:208)
  at
it.geosolutions.imageio.gdalframework.GDALCommonIIOImageMetadata.<init>(GDALCommonIIOImageMetadata.java:186)
  at
it.geosolutions.imageio.gdalframework.GDALImageReader.createDatasetMetadata(GDALImageReader.java:295)
  at
it.geosolutions.imageio.gdalframework.GDALImageReader.initialize(GDALImageReader.java:260)
  at
it.geosolutions.imageio.gdalframework.GDALImageReader.checkImageIndex(GDALImageReader.java:176)
  at
it.geosolutions.imageio.gdalframework.GDALImageReader.getDatasetMetadata(GDALImageReader.java:119)
  at
it.geosolutions.imageio.gdalframework.GDALImageReader.getImageMetadata(GDALImageReader.java:1280)
  at
org.geotools.coverageio.gdal.BaseGDALGridCoverage2DReader.setCoverageProperties(BaseGDALGridCoverage2DReader.java:97)
  at
org.geotools.coverageio.BaseGridCoverage2DReader.<init>(BaseGridCoverage2DReader.java:200)
  at
org.geotools.coverageio.gdal.BaseGDALGridCoverage2DReader.<init>(BaseGDALGridCoverage2DReader.java:80)
  at org.geotools.coverageio.gdal.nitf.NITFReader.<init>(NITFReader.java:64)
  at
org.geotools.coverageio.gdal.nitf.NITFFormat.getReader(NITFFormat.java:93)
  at
org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:434)
  at
org.vfny.geoserver.global.CoverageStoreInfo.getReader(CoverageStoreInfo.java:339)
  at
org.vfny.geoserver.action.data.DataCoveragesNewAction.newCoverageConfig(DataCoveragesNewAction.java:95)
  at
org.vfny.geoserver.action.data.CoverageStoresEditorAction.execute(CoverageStoresEditorAction.java:90)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
  at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
  at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at
  at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at
  at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at
  at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at
  at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  at
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  at
  at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at
  at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at
  at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
  at
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
  at
org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
  at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
  at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
  at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
  at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
  at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
View this message in context: http://www.nabble.com/RPF-Support-in-GeoServer-tp21361665p21361665.html
Rick,
The GDAL Library provides a specific driver for Raster Product Format/RPF (a.toc) files.
However, the GDAL based ImageIO-ext project (the library on which geotools->geoserver are based) doesn’t actually provide support for it. (although it could be added with some days of work)
Can you give me your test-data so I can do some tests on it with the GDAL library?
Daniele
On Thu, Jan 8, 2009 at 10:47 PM, Rick McAdams <richard.b.mcadams@anonymised.com> wrote:
should be image data in that file (which there isn’t because the file just
describes the data underneath it’s directory structure). I know the NITF
Rick
won’t help but thought I would throw it out there if any found it useful.
at
at
it.geosolutions.imageio.gdalframework.GDALCommonIIOImageMetadata.(GDALCommonIIOImageMetadata.java:264)
at
it.geosolutions.imageio.gdalframework.GDALCommonIIOImageMetadata.(GDALCommonIIOImageMetadata.java:288)
at
it.geosolutions.imageio.gdalframework.GDALCommonIIOImageMetadata.(GDALCommonIIOImageMetadata.java:208)
at
it.geosolutions.imageio.gdalframework.GDALCommonIIOImageMetadata.(GDALCommonIIOImageMetadata.java:186)
at
at
at
at
at
at
at
org.geotools.coverageio.BaseGridCoverage2DReader.(BaseGridCoverage2DReader.java:200)
at
org.geotools.coverageio.gdal.BaseGDALGridCoverage2DReader.(BaseGDALGridCoverage2DReader.java:80)
at org.geotools.coverageio.gdal.nitf.NITFReader.(NITFReader.java:64)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Check out the new SourceForge.net Marketplace.
It is the best place to buy or sell services for
just about anything Open Source.
http://p.sf.net/sfu/Xq1LFB
Geoserver-users mailing list
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
I was just curious if there was any progress or effort made in the
ImageIO-ext project to provide support for RPF a.toc files. I would not mind
taking a crack at adding support myself if someone could give a little
guidance on the best or most proper way of going about including it into the
ImageIO-ext project.
Wally Atkins
Daniele Romagnoli wrote:
Rick,
(a.toc) files.
geotools->geoserver are based) doesn't actually provide support for it.
library?
Daniele
<richard.b.mcadams@anonymised.com>wrote:
into
there
just
load
Rick
Probably
Warning 1: The file
thrown:
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
       at
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
View this message in context: http://old.nabble.com/RPF-Support-in-GeoServer-tp21361665p29471658.html
