[Geoserver-users] Running geoserver with IP address instead of localhost
I've just installed geoserver and started some experiments with WFS. Right
now I'm running WFS locally with address of localhost and port 8080. e.g
http://localhost:8080/geoserver/wfs?request=GetCapabilities&service=WFS&version=1.0.0
If I want to access this WFS remotely say with IP address 10.129.13.8, so
address would be
http://10.129.13.8:8080/geoserver/wfs?request=GetCapabilities&service=WFS&version=1.0.0
But I'm not able to access WFS remotely with this address. Can anyone tell
me the configuration to be made for accessing geoserver functionalities
from remote machine?
Sanket Patle.
Hi Sanket,
There should be no additional GeoServer configuration necessary (unless you are going through a proxy). The only configuration should be with regard to your network, and any firewalls thats is setup. Basically make sure that there are no firewalls on the client or server blocking traffic on port 8080.
And of course ensure the client can indeed see the server via the specified ip address. A quick ping of the server from the client should verify that part.
-Justin
Sanket Chandulal Patle wrote:
address would be
Sanket Patle.
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
