Is there a way to pass to postgis the name of the geoserver user who is adding or modifying data through WFS?
Or that can be accomplished only on client side?
thank you
maxx
thank you
maxx
You can probably use this:
http://docs.geoserver.org/stable/en/user/data/database/sqlsession.html#data-sqlsession
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
