[Geoserver-users] Scale discrepancy between Web Mercator and BC-Albers
I am not sure if I understood the problem but I wonder how the true scale suits together with Web Mercator. I guess that you do not expect that the tiles of the same zoom level would use different styles at equator than in Canada or Finland even the true scale differs a lot.
-Jukka Rahkonen-
Martin Davis wrote:
We are displaying map images in Web Mercator, from a GeoServer with native CRS as BC-Albers (EPGS:3005).
We are using an OpenLayers client to display the map images. We have confirmed that the geodetic scale displayed by OpenLayers is approximately the true scale of the map images (modulo the fact that OL uses a fixed resolution of 72 DPI).
Based on the zoom levels at which layers become visible, it appears that GeoServer’s internal computed scale is from 2 to 4 times larger than the client scale.
Is this expected?
Is there any way to determine a way to map between client scale and Geoserver scale, so that we can configure the client to track GeoServer visibility faithfully?
Is there any way to display the internal GeoServer scale to make it possible to confirm if this analysis is correct?
GeoServer ver 2.6 (although I believe this is happening in 2.8 as well)
Yes, we realize that’s an issue. In our case we’re only concerned with a relatively small area (the province of BC), so the variation in true scale across the area is not that large (around 20%). We realize that we won’t get 100% correlation, but we’d like to at least get it looking right better than 50% of the time!
The issue is that it’s very hard to determine what a scale limit in a SLD corresponds to in terms of client (true, screen) scale. It seems odd that the GeoServer scale would be a factor of 2 or more different to the true (image) scale.
There does appear to be a rough correlation, which may even be a linear factor. But it’s hard to tell without seeing the exact scale that GeoServer is using in its SLD algorithm.
As examples, here’s some scale limits from SLDs, with the corresponding largest client scale (approximate) at which the layer is visible
SLD Client Zoom Level
10,000,000 4,399,000 6
6,000,000 2,297,000 7
2,000,000 565,000 9
1,000,000 282,000 10
500,000 143,000 11
20,000 8,957 15
On Mon, Feb 15, 2016 at 2:35 PM, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
Is this expected?
Are you suggesting that GeoServer computes the scale at a single known point for all map request extents, no matter where on the globe they are located? Does the OGC standard specify this?
If so, I guess that might explain the discrepancy between SLD scale and true image scale, at our latitudes (49 to 60) ?
-Jukka Rahkonen-
Is this expected?
On Tue, Feb 16, 2016 at 12:05 AM, Martin Davis <mtnclimb@anonymised.com> wrote:
The OGC standard basically defines (brace yourself) an "cylindrical earth"
model in the SLD specification, that's what GeoServer implements, at least
for
geographic coordinate systems.
For projected ones it's the "flat map" scale one, measured in the projected
coordinates, which is also very far away from a true scale (measured along
a geodetic distance) especially at those latitudes
and using that projection.
If you really want to break the standards GeoServer gives you a hand by
offering a vendor param to compute the scale
in the accurate (geodetic) way:
http://docs.geoserver.org/latest/en/user/services/wms/vendor.html#scalemethod
We normally use that for printouts :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Thanks, Andrea. I suspected this might be the cause of the issue.
Is there a way to view the scale computed for a map request? That might let us correlate the client (geodetic) scale to “OGC scale”, so we can translate between the two.
On Tue, Feb 16, 2016 at 12:40 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
The OGC standard basically defines (brace yourself) an “cylindrical earth” model in the SLD specification, that’s what GeoServer implements, at least for
For projected ones it’s the “flat map” scale one, measured in the projected coordinates, which is also very far away from a true scale (measured along a geodetic distance) especially at those latitudes
If you really want to break the standards GeoServer gives you a hand by offering a vendor param to compute the scale
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Feb 16, 2016 at 6:10 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
let us correlate the client (geodetic) scale to "OGC scale", so we can
You can use the decorations:
http://docs.geoserver.org/stable/en/user/advanced/wmsdecoration.html
A "correlation" might be possible in a very specific local area, but just
so that we are on the same
page, the math is wildly different, so you could have a rough linear
correlation in a town,
not sure you can have that in a larger area (something spanning degrees,
especially
at that latitude where the mercator scale factor starts to diverge)
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks for the advice - and for the warning. Sigh…
On Tue, Feb 16, 2016 at 9:35 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
A “correlation” might be possible in a very specific local area, but just so that we are on the same
page, the math is wildly different, so you could have a rough linear correlation in a town,
not sure you can have that in a larger area (something spanning degrees, especially
Ing. Andrea Aime
@geowolf
Technical Lead
Good news on this. Further experimentation revealed that it is possible to get reasonably good agreement between scales in OpenLayers and GeoServer using the following approach:
  • use OpenLayers NON-geodesic (nominal) scale calculation
  • set OpenLayers DOTS_PER_INCH to match the GeoServer value of 90
This produced OL scales that were in good agreement with the GeoServer values (close enough for government work, anyway 8^). For example, at a map nominal scale of 541,679 GeoServer computed the scale of 545,979
This was greatly assisted by Andrea’s suggestion of using WMS Decorations, in conjunction with some enhancements to my WMS Viewer ( http://dr-jts.github.io/maptest/maptest.html ).
For those interested, the following was used to display the GeoServer scale on each map image:
GetMap parameter
format_options=layout:scaleratio
WMS Decoration Layout file scaleratio.xml:
Ing. Andrea Aime
@geowolf
Technical Lead
