Hi List,
I have a number of layers that have scale denominators (aka, scale thresholds) in their styles and these work correctly.
My question is - is there a way for me to find out from the WMS what these scale denominators are? They don’t appear to show up in a GetCapabilities request or a WMS 1.1.1 “describeLayer” request. I can’t see anything obvious in the spec (ctrl-f for “scale” and “denominator”).
Anyone have any ideas if this is possible?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
