[Geoserver-users] Schemaless WFS spatial queries in GeoServer ?
The WFS spec supports “schemaless” (or perhaps “anonymous” spatial queries against featuretypes via the BBOX parameter. But if a more complex query geometry is required (e.g. polygon), it’s necessary to create a Filter, which then needs to have the spatial propertyname provided.
This means that clients need more metadata about featuretype schemas to do polygon queries. This seems a bit inconsistent, since presumably the server mechanism can handle schemaless queries (since it can support BBOX).
I suspect I know the answer to this, but I’ll ask it anyway… Is there any extension in GeoServer that supports WFS queries with a polygonal query geometry WITHOUT requiring a property name?
This is the kind of thing the CITE tests hit, so you can try enabling CITE mode on your WFS and and using something like . - which should check against all geometry attributes in a feature.
Other than that I would recommend using GetFeatureInfo and asking it to return GML.
Geoserver-users mailing list
Jody Garnett
Il 19/ago/2015 23:34, “Martin Davis” <mtnclimb@anonymised.com> ha scritto:
Well, that seems to work, by simply omitting content from the element.
So next questions: Is this a stable feature of GeoServer? And if it should probably be documented somewhere? (In the Filter pages perhaps - although does this work in SLDs as well?)
Has been there for a long time, I guess we could document it.
Also, did you want to share this with the list?
Yep… sorry, answering from tablet, did not notice I was not replying to all
Not sure I understand… I think I want to do something that is outside the spec, and am wondering if GS has a way to do it. So not sure how the CITE test will help?
GetFeatureInfo is not an option, since we need to query by a polygon.
On Wed, Aug 19, 2015 at 9:21 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Adding the list into the loop
Il 19/ago/2015 21:52, “Andrea Aime” <andrea.aime@anonymised.com> ha scritto:
Going by memory, GeoServer internally represents the “default geometry” as an empty string, so you may want to try a property name without content, or one with an empty CDATA section in place of the name. Let us know if any of that works
I was also thinking about using some default geometry if no property is given but then I had a look on the FES 2.0 standard. I says about BBOX filter, by using language which is a bit hard to understand for layman like I:
"If there is only one argument (i.e. one child element specified for the operator, the calling service shall apply the operator to the geometric values of all the spatial properties of the resource[11]. In this case, the operator shall evaluate to true if all tested spatial property values fulfill the spatial relationship implied by the operator. Otherwise, the operator shall evaluate the specified arguments (i.e. the two child elements) and test whether their geometric values satisfy the implied spatial relationship. "
The same applies to DWithin and Beyond operators. For the rest operators FES refers to ISO 19125-1:2004, 6.1.14.
So, not one “default geometry” property but “all geometry properties”. I think I would rather like have that as “any geometry property”. If one has something like WFS feature type for administrational units which has separate geometries for polygon and point geometries, the “all geometries” rule makes BBOX query to find the polygon geometry only if also the point geometry happens to be inside the box.
Fortunately feature types with multiple geometries are uncommon. But perhaps Geoserver could make it better than OGC and accept CQL_FILTER with all these variants:
INTERSECTS(the_geom, POLYGON((-90 40, -90 45, -60 45, -60 40, -90 40)))
  • explicit geometry property name
INTERSECTS (all, POLYGON((-90 40, -90 45, -60 45, -60 40, -90 40)))
  • requires that all geometries intersects
INTERSECTS (any, POLYGON((-90 40, -90 45, -60 45, -60 40, -90 40)))
  • it is enough if one geometry intersects
INTERSECTS (POLYGON((-90 40, -90 45, -60 45, -60 40, -90 40))):
  • following what FES 2.0 says about BBOX, Dwithin, and Beyond, means the same as “all”.
-Jukka Rahkonen-
