[Geoserver-users] SchemaLocations WFS Responses
Hello everyone,
currently we are facing problems with the schemaLocations used in the WFS-Responses.
The user downloaded all the schemaLocations, which were all referenced locally until he came to this reference:
https://sgx.geodatenzentrum.de/web_geoserver_schemas/gml/3.2.1/coordinateOperations.xsd
Here is the problematic schemaLocation to schemas.opengis.net. Now the problems continue, because the objects will be defined twice - locally from sgx.geodatenzentrum.de and from schemas.opengis.net.
Is there a workaround for this problem or a possibility to solve it?
Kind regards,
anna-lena
Hello,
Unfortunately there was no reply to my question. Is it useful to open an issue on jira?
Kind regards,
Anna-Lena
Am 31.01.2024 um 09:50 schrieb Anna-Lena Hock <anna-lenahock@anonymised.com>:
Hello everyone,
Here is the problematic schemaLocation to schemas.opengis.net. Now the problems continues, because the objects will be defined twice - locally from sgx.geodatenzentrum.de and from schemas.opengis.net.
Kind regards,
anna-lena
Hi Anna,
it is your right to open a ticket in Jira. and if you provide steps to reproduce (sample data, mapping files and so on) it would
be useful as well. But I very much doubt it will change anything, in terms of getting an answer.
If you need a solution now, see this guide:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-fixes,-improvements-and-new-features-in-GeoServer
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Ï’m struggling to understand what you are asking about.
You’re saying:
What was he using when he downloaded those schemaLocations?
How did those xsd-files end up on that server https://sgx.geodatenzentrum.de/web_geoserver_schemas?
I suppose a solution would be to go through all the xsd-files at that location to make sure none of them are referring to an external entity if a local copy is present.
Best regards,
Roar Brænden
  1. feb. 2024 kl. 13:07 skrev Anna-Lena Hock via Geoserver-users <geoserver-users@lists.sourceforge.net>:
Hello,
Kind regards,
Anna-Lena
Hello everyone,
Kind regards,
anna-lena
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.comge.net
Hello,
Usually the schemaLocations are generated by Geoserver and use the same schemaLocation like the service-uri. Every schemaLocation points to those local uri, but there is only one schemaLocation which points to schemas.opengis.net. And there are other references to schema.opengis.net which are downloaded and defined twice in concequence - once by schema.opengis.net and our local uri.
I hope this one was better to understand.
I will open an issue on jira now.
Thanks for the reply!
Kind regards
Anna-Lena
Am 21.02.2024 um 08:17 schrieb Roar Brænden roar.brenden.no@anonymised.com:
You’re saying:
Best regards,
Roar Brænden
Hello,
Kind regards,
Anna-Lena
Hello everyone,
Kind regards,
anna-lena
Anna,
do you need them to be all local, or would it be ok if they were all sitting on schemas.opengis.net?
If the latter is ok, then maybe this setting, found in the WFS admin page, is an answer: “encode canonical wfs schema location”
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
