[Geoserver-users] sde data is not visible
I have included SDE plugin and accessing the sde layers. Layer data is
visible in Open Layers. when I download the Google Earth a KML file is being
downloaded but with no network link and some times gives me 502 bad gate way
error.
When I check the logs I seeing Unable to find the property.
2014-03-30 17:59:52,585 WARN [geoserver.web] - Unable to reproject layer
qatarrail:uip_villaggioto spherical mercator
2014-03-30 17:59:52,585 INFO [geoserver.web] - Unable to find property:
'format.wms.application/vnd.google-earth.kmz' for component:
[class=org.geoserver.web.demo.OpenGeoMapPreviewPage]
'format.wms.image/png; mode=8bit' for component:
2014-03-30 17:59:52,586 INFO [geoserver.web] - Unable to find property:
'format.wms.text/html' for component:
'format.wms.application/xml' for component:
2014-03-30 17:59:52,589 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,592 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,593 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,595 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,596 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,599 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,602 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,603 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,606 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,607 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,609 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,610 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,613 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,616 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:52,617 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:57,077 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:57,078 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:57,082 INFO [geoserver.web] - Unable to find property:
'format.wfs.application/vnd.google-earth.kml xml' for component:
'format.wfs.KML' for component:
2014-03-30 17:59:57,083 INFO [geoserver.web] - Unable to find property:
'format.wfs.application/json' for component:
2014-03-30 17:59:57,092 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:57,093 INFO [geoserver.web] - Unable to find property:
2014-03-30 17:59:57,094 INFO [geoserver.web] - Unable to find property:
Prasanth.
View this message in context: http://osgeo-org.1560.x6.nabble.com/sde-data-is-not-visible-tp5132106.html
Hi Prasanth,
can you please give us some more details about you GeoServer configuration?
Which GeoServer version are you using?
Are you doing reprojections? which ones?
Are you using custom stiles?
Also, you can try enabling and higher logging level to get more info about the error in the log.
Thank you
Lorenzo Pini
Software Engineer
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK for more information.
Via Poggio alle Viti 1187
On Sun, Mar 30, 2014 at 5:19 PM, mallelaprasanth <mallelaprasanth@anonymised.com> wrote:
error.
‘format.wms.application/vnd.google-earth.kmz’ for component:
‘format.wms.image/png; mode=8bit’ for component:
‘format.wms.text/html’ for component:
‘format.wms.application/xml’ for component:
‘format.wfs.application/vnd.google-earth.kml xml’ for component:
‘format.wfs.KML’ for component:
‘format.wfs.application/json’ for component:
Prasanth.
Geoserver-users mailing list
