Hi Gabriel & Chris
I now upgraded to version 1.3.3 and used the latest arcsde.jar, but this did not bring any success. I seem to obtain even worse results as before, since the sensible image wouldn't show up any more. (By the way, this version seems to work worse with mozilla than the 1.3.0, the use ie seems to work fine!)
Answers to your questions:
1- I use the green.sld as delivered with the war-installation (as recommended by Chris)
2- FINE log: see attachment (short portion containing a request on the sde-featureclass)
I hope, you will have any helpful hints for me... many thanks for your effort!
regards, bernd
Von: Gabriel Roldán [mailto:groldan@anonymised.com]
Gesendet: Montag, 11. September 2006 21:06
An: geoserver-users@lists.sourceforge.net
Cc: Chris Holmes; Hebel Bernd
Betreff: Re: [Geoserver-users] SDE-FeatureType is not displayed
Hi Hebel,
trying yo figure out what the problem can be without much success.
the following request returns a blank image:
http://uwis-yggdrasil.ethz.ch:8080/geoserver/wms/GetMap?LAYERS=sde:MANAGER.GEWAESSERNETZ&BBOX=620000,205999,655000,217999&WIDTH=400&HEIGHT=300&FORMAT=image/png&STYLES=default_line
but it is obvious the datastore is throwing out features since WFS works just fine. The layer default style also _seems_ properly defined since GetLegendGraphic returns a sensible image with a line.
Sending a GetMap with an inline SLD document doesn't seems to work also.
So there are two things you can do to help us find out what's happening:
1- send us the sld document you're using for the default_line style
2- set the logging level to FINE and send us the log file, or at least the portion related to the above getmap request
regards,
Gabriel
On Saturday 09 September 2006 01:33, Chris Holmes wrote:
Hey, sorry for the late response.
First off you may try to upgrade to 1.3.3 and download the latest
arcsde jar. It had a few improvements.
I just tried your server and was able to get data out as GML, see:
http://uwis-yggdrasil.ethz.ch:8080/geoserver/wfs/GetFeature?typename=sd
e:MA
NAGER.GEWAESSERNETZ&maxfeatures=10
So it's definitely connected. Did you make a style for your map? Or
at least use a style that would be compatible with your data?
If you get 1.3.3 there's a very basic style wizard, that should allow
you to create a very basic style for your data, you may try that. Or
just select 'green' or the other line style from the 'default style'
drop down when you edit your features.
best regards,
Chris
Hebel Bernd wrote:
> Dear GeoServer-users
> Trying to set up a connection to a ArcSDE 9.1 (based on Oracle 9i)
> with GeoServer 1.3.0 (Tomcat war).
> Configuring Namespace, Store and FeatureType went fine, I see the
> FeatureType (sde:MANAGER.GEWAESSERNETZ) in the preview-list
> (http://uwis-yggdrasil.ethz.ch:8080/geoserver/mapPreview.do).
> However, when I open the preview itself
> (http://uwis-yggdrasil.ethz.ch:8080/geoserver/data/generated/sde_MAN
> AGER .GEWAESSERNETZ.html), the map remains empty.
> What goes wrong, have any ideas on what I should check?
> Regards, Bernd
> ----- Using Tomcat but need to do more? Need to support web
> services, security?
> Get stuff done quickly with pre-integrated technology to make your
> job easier Download IBM WebSphere Application Server v.1.0.1 based
> on Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=12
> 1642 _______________________________________________
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
> !DSPAM:1003,44eef99f108431410093335!
Gabriel Roldán (groldan@anonymised.com)
Axios Engineering (http://www.axios.es)
Tel. +34 944 41 63 84
Fax. +34 944 41 64 90
geoserver.log (32 KB)
