On Mon, Dec 8, 2014 at 8:43 PM, Mark Volz <MarkVolz@anonymised.com> wrote:
Hello
I would like to configure leaflet-search
http://labs.easyblog.it/maps/leaflet-search/ to search against parcels
that are stored in GeoServer. In their examples their geoJSON is expecting
the latitude and longitude to be in separate columns, while GeoServers
default geoJSON format has the coordinates in an array. A member of the
leaflet mail list mentioned that I should add a column in my shapefile for
lat and long so I can use leaflet search. I don’t know if this would be
the best solution as it would imply that I would need to change the data
for all of my layers in GeoServer. Instead I would like to check with this
group to see if anyone has had success in either 1) creating a geoJSON
template that populates the required latitude and longitude values from the
shape itself,
You might have some luck using the XSLT output format generator:
http://docs.geoserver.org/stable/en/user/extensions/xslt/index.html
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
