[Geoserver-users] securing an Openlayers web mapping application and GeoServer layers with a single password
Hello,
I would like to add security to an openlayers based web mapping application. I know that I can add a password to GeoServer layers to protect the data. In addition, I also know that I can add a password in Apache to protect the Openlayers application. Is there a way to combine the access between GeoServer and Openlayers (Apache) so that users only need to enter a single password to access a web mapping application that has secure GeoServer Layers?
Thanks
Mark Volz, GISP
GIS Specialist
Lyon County, MN
(507) 532-8218
When I do a gdal_retile.py on some Ordnance Survey Raster images i get the warning;
gdal_retile.py -v -levels 9 -ps 2048 2048 -co ‘TILED=YES’ -co ‘BLOCKXSIZE=256’ -co ‘BLOCKYSIZE=256’ -s_srs EPSG:27700 -targetDir pyramid --optfile …/tiles$thedir.txt
The script I run is
#!/bin/bash
export thedir=pwd
export thedir=basename $thedir
echo $thedir
mkdir pyramid
ls *tif > …/tiles$thedir.txt
I think I have a recent gdal.
gdalinfo --version tell me GDAL 1.10.0, released 2013/04/24
Warning 1: TIFFFetchNormalTag:Incompatible type for “RichTIFFIPTC”; tag ignored
What am I missing?
Russ
Dear Russell,
I believe this question is more suited for the GDAL mailing list :).
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
warning;
gdal_retile.py -v -levels 9 -ps 2048 2048 -co 'TILED=YES' -co
'BLOCKXSIZE=256' -co 'BLOCKYSIZE=256' -s_srs EPSG:27700 -targetDir pyramid
--optfile ../tiles$thedir.txt
The script I run is
#!/bin/bash
export thedir=`pwd`
export thedir=`basename $thedir`
echo $thedir
mkdir pyramid
ls *tif > ../tiles$thedir.txt
Warning 1: TIFFFetchNormalTag:Incompatible type for "RichTIFFIPTC"; tag
ignored
What am I missing?
Russ
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It's a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
Geoserver-users mailing list
It is not an error, it is an informational warnign message and it means that the original tiff file contains IPTC tag and the libtiff library used by GDAL claims that the type of the tag is not correct. Perhaps the type is LONG instead of UNDEFINED or BYTE http://www.awaresystems.be/imaging/tiff/tifftags/iptc.html. All warnings coming from GDAL are informational. The critical issues are reported as errors. In this case you are told that the RichTIFFIPTC tag is ignored but this tag has no meaning for gdalretile.py and you can ignore the warning.
-Jukka Rahkonen-
gdal_retile.py -v -levels 9 -ps 2048 2048 -co 'TILED=YES' -co 'BLOCKXSIZE=256' -co 'BLOCKYSIZE=256' -s_srs EPSG:27700 -targetDir pyramid --optfile ../tiles$thedir.txt
The script I run is
#!/bin/bash
export thedir=`pwd`
echo $thedir
mkdir pyramid
Warning 1: TIFFFetchNormalTag:Incompatible type for "RichTIFFIPTC"; tag ignored
What am I missing?
Russ
