[Geoserver-users] Securing with digest
I cannot get digest authentication to work in GeoServer 2.8.1. Without digest it works properly. GeoServer is bundled with Jetty and I run them under Linux. Because it did not work with my own data I went back to basics and tried the tutorial:
  http://docs.geoserver.org/stable/en/user/security/tutorials/digest/index.html
It didn't work either. However, the dialog in step 9 is different than mine although the tutorial version should be correct. Also default roles are different (ADMIN vs. ROLE_ADMINISTRATOR). Can anyone give me simple instructions how to activate digest in GeoServer 2.8.1?
Best regards,
Petteri Packalen
Hi
Unfortunately, digest auth does not work in some situations, don’t know why. Can you open an issue in the issue tracker.
Christian
On Tue, Feb 2, 2016 at 2:42 PM, Petteri Packalen <petteri.packalen@anonymised.com1…> wrote:
It didn’t work either. However, the dialog in step 9 is different than mine although the tutorial version should be correct. Also default roles are different (ADMIN vs. ROLE_ADMINISTRATOR). Can anyone give me simple instructions how to activate digest in GeoServer 2.8.1?
Best regards,
Petteri Packalen
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
On Wed, Feb 3, 2016 at 5:22 PM, Christian Mueller <
christian.mueller@anonymised.com> wrote:
Hi
Unfortunately, digest auth does not work in some situations, don't know
Hi Christian,
I am wondering if there might be user error there. Like, I would expect
digest to have to be put
in the OGC filter chain in exactly the same position as the basic one, in
any other position
it might not work correctly, right?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Is the problem Jetty specific? I can give a try with Apache.
I will open an issue.
Petteri
On 3.2.2016, at 18.22, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi
Christian
On Tue, Feb 2, 2016 at 2:42 PM, Petteri Packalen <petteri.packalen@anonymised.com> wrote:
Best regards,
Petteri Packalen
@Andrea.
Replacing the basic auth filter with the digist auth filter is the most
common use case but it you can use this filter on any chain.
Yes, this was exactly what I did.
@Petteri
It is not Jetty specific.
Yep, I noticed. Switching to Tomcat7 did not solve the problem.
Petteri
On Wed, Feb 3, 2016 at 6:51 PM, Petteri Packalen <petteri.packalen@...7441...<mailto:petteri.packalen@…7441…>> wrote:
Petteri
On 3.2.2016, at 18.22, Christian Mueller <christian.mueller@...5445...<mailto:christian.mueller@…5445…>> wrote:
Hi
Unfortunately, digest auth does not work in some situations, don't know why. Can you open an issue in the issue tracker.
Christian
On Tue, Feb 2, 2016 at 2:42 PM, Petteri Packalen <petteri.packalen@...7441...<mailto:petteri.packalen@…7441…>> wrote:
Best regards,
Petteri Packalen
Geoserver-users@lists.sourceforge.net<mailto:Geoserver-users@lists.sourceforge.net>
This problem is still seen on Geoserver 2.12.1 and 2.13-SNAPSHOT (12/18/17).
It seems to apply to all digest authentication requests. I have only tested
with the bundled Jetty. Using basic authentication with the same requests
works as expected.
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
