Hi all!
I need protect all services (WMS, WFS, WFS-T and WCS) in my Geoserver installation by usr/passw. I try some modifications in two files in data/security folder. I protect services but I can't access when
I put the correct usr/passw.
If I uncomment default lines in service.properties and users.properties, security works fine for WFS and WFS-T. What are the lines for protect WCS and WMS. Where I read some tutorial about geoserver 1.6 security system.
Thanks in advance, Alt
Hi Alfonso,
What lines did you try? For instance if you wanted to protect all of wms:
service.properties:
wms=ROLE_WMS
user.properties:
<user>=<password>,ROLE_WMS
Hope that helps.
-Justin
Alfonso Fraguas Bravo wrote:
Hi all!
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
!DSPAM:4007,47d19a47241631637810514!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Hi Justin,
you had help me. I'm confused between usr/passw in wfs sample because are the same... I'm stupid. Now all works fine. Thank you very much. Do you know if password will be encrypted in future versions?
Salu2, Alt
Justin Deoliveira escribió:
Hi Alfonso,
service.properties:
wms=ROLE_WMS
user.properties:
Hope that helps.
-Justin
Hi all!
Alfonso Fraguas Bravo ha scritto:
Hi Justin,
Not before we have a UI to handle password editing I guess... who's
gonna be able to edit them otherwise?
Unfortunately this means we'll have to wait for the new UI, or for
some martyr willing to make a UI with the current framework.
I guess we could make a compromise and have a setting allowing
the usage of encrypted passwords and a command line tool that
can be used to add/remove/edit users and their passwords.
The patch contained in this issue:
http://jira.codehaus.org/browse/GEOS-1793
can provide some inspiration on writing such a tool.
