[Geoserver-users] Security with REST API
Hi All,
I am trying to create security rules on GeoServer through the REST API, I am trying to create the tutorial steps of the link below via REST, however, I am not getting success.
https://docs.boundlessgeo.com/suite/1.1.1/sysadmin/security/multiuser/index.html
I was able to create users and workspaces without problems, but when I get to the ROLES, it gives an error. The closest to creating that I got was this way:
curl -v -u admin:geoserver -XPOST -H “Content-type: text/xml” -d “ROLE_EDIT” http://localhost:8080/geoserver/rest/security/roles
And the GeoServer returned the following message to me: HTTP / 1.1 405 Method Not Allowed
What am I doing wrong? Is it possible to create ROLES and set permissions via REST?
Best Regards,
Fernando Quadro
http://www.fernandoquadro.com.br
https://www.linkedin.com/in/fernandoquadro/
That documentation is not provided by the community, we would welcome the contribution of an example once you get it working.
I encourage you to check the test cases, for that specific rest end point, as a good place to find a working/tested example.
Jody Garnett
Hi Fernando,
To create a new role I am using the following endpoint:
POST
Headers:
Accept: application/json
Content-Type: application/x-www-form-urlencoded
Authorization: Basic your-authorization
https://www.your.geoserver.url.com/rest/security/roles/role/
Hope this helps.
Cheers.
Samy Otero
PSD | Software Developer
www.psdrcs.com
London | 148 Fullarton St. 9th floor.
Burlington | 5045 South Service Rd.
