[Geoserver-users] Seeding fails with "Alpha images must have the same sample size as the sources"
Dear all,
I am trying to seed a certain layer. However, seeding is always aborted with the error message “java.lang.IllegalArgumentException: Alpha images must have the same sample size as the sources”.
The WMS request is like this:
https://security.geobasis-bb.de:443/wss/service/WMS-ALKIS/httpauth?SERVICE=WMS&LAYERS=adv_alkis_gebaeude&FORMAT=image%2Fpng&HEIGHT=1134&TRANSPARENT=TRUE&REQUEST=GetMap&WIDTH=1234&BBOX=241422.08804878494,5682813.523432538,242292.88804878492,5683614.323432538&STYLES=&SRS=EPSG:25833&VERSION=1.1.1
(Sorry, the service is password protected as it’s an official service and I cannot paste it here :-/ but I attached the retrieved image. It’s just a plain transparent PNG, 1234x1134px with 455 Bytes).
I’ve seen the thread here http://osgeo-org.1560.x6.nabble.com/Transparent-argument-and-Geoserver-errors-td5048880.html (Apr 2013) about the “transparent” argument but do not know if it is related.
Full traceback is below, GeoServer 2.3.5 with builtin GWC.
Best,
Jens
18 Nov 11:47:57 DEBUG [seed.SeedTask] - Seed failed at ConveyorTile[{76,9784,8} Iter02_EPSG:25833_LPT image/png] after 30 of 51 attempts.
18 Nov 11:47:57 DEBUG [gwc.layer] - → GWC Seeder Thread-7 submitting getMap request for meta grid location [76, 9784, 8] on org.geoserver.gwc.layer.GeoServerMetaTile@…6247…
18 Nov 11:47:57 INFO [geoserver.wms] -
Request: getServiceInfo
18 Nov 11:47:57 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
18 Nov 11:47:57 DEBUG [geoserver.ows] - establishing null style for lpt:adv_alkis_gebaeude
18 Nov 11:47:57 DEBUG [geoserver.wms] - setting up map
18 Nov 11:47:57 DEBUG [wms.map] - setting up 1224x1124 image
18 Nov 11:47:57 WARN [wms.map] - Failed to compare data and request envelopes, proceeding with rendering anyways
java.lang.NullPointerException: Unable to transform referenced envelope, crs has not yet been provided.
at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:658)
at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:624)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.readBestCoverage(RenderedImageMapOutputFormat.java:1207)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:861)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:333)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:255)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:127)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:466)
at org.geoserver.wms.GetMap.run(GetMap.java:201)
at org.geoserver.wms.GetMap.run(GetMap.java:111)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:356)
at sun.reflect.GeneratedMethodAccessor165.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:61)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:35)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:73)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:54)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:54)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy23.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor175.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.geoserver.gwc.GWC.dispatchOwsRequest(GWC.java:1138)
at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:552)
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:497)
at org.geoserver.gwc.layer.GeoServerTileLayer.seedTile(GeoServerTileLayer.java:691)
at org.geowebcache.seed.SeedTask.doActionInternal(SeedTask.java:136)
at org.geowebcache.seed.GWCTask.doAction(GWCTask.java:76)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:36)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:25)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:724)
18 Nov 11:47:57 DEBUG [geotools.map] - Issuing request: https://security.geobasis-bb.de:443/wss/service/WMS-ALKIS/httpauth?SERVICE=WMS&LAYERS=adv_alkis_gebaeude&FORMAT=image%2Fpng&HEIGHT=1134&TRANSPARENT=TRUE&REQUEST=GetMap&WIDTH=1234&BBOX=241422.08804878494,5682813.523432538,242292.88804878492,5683614.323432538&STYLES=&SRS=EPSG:25833&VERSION=1.1.1
18 Nov 11:47:57 DEBUG [data.ows] - Executed request to URL: https://security.geobasis-bb.de:443/wss/service/WMS-ALKIS/httpauth?SERVICE=WMS&LAYERS=adv_alkis_gebaeude&FORMAT=image%2Fpng&HEIGHT=1134&TRANSPARENT=TRUE&REQUEST=GetMap&WIDTH=1234&BBOX=241422.08804878494,5682813.523432538,242292.88804878492,5683614.323432538&STYLES=&SRS=EPSG:25833&VERSION=1.1.1
18 Nov 11:47:57 DEBUG [geotools.rendering] - Drawing coverage GridCoverage2D[“Gebäude”, GeneralEnvelope[(241422.08804878494, 5682813.523432538), (242292.88804878492, 5683614.323432538)], DefaultProjectedCRS[“ETRS89 / UTM zone 33N”]]
│ RenderedSampleDimension(“Gebäude”:[0.0 … 3.0])
│ ‣ Category(“Gebäude”:[0…3])
└ Image=WritableRenderedImageAdapter
18 Nov 11:47:57 DEBUG [geotools.rendering] - Transforming coverage envelope with transform PARAM_MT[“Affine”,
PARAMETER[“num_row”, 3],
PARAMETER[“num_col”, 3]]
18 Nov 11:47:57 DEBUG [geotools.rendering] - Using interpolation javax.media.jai.InterpolationNearest@…6248…
18 Nov 11:47:57 DEBUG [geotools.rendering] - Raster Symbolizer
Request: getMap
Width = 1224
Height = 1124
Palette = null
Tiled = false
SRS = EPSG:25833
FeatureVersion = null
Styles = [StyleImpl[ name=Default Styler]]
Layers = [org.geoserver.wms.MapLayerInfo@…6249…]
MaxFeatures = null
Exceptions = SE_XML
Crs = PROJCS[“ETRS89 / UTM zone 33N”,
GEOGCS[“ETRS89”,
DATUM[“European Terrestrial Reference System 1989”,
SPHEROID[“GRS 1980”, 6378137.0, 298.257222101, AUTHORITY[“EPSG”,“7019”]],
TOWGS84[0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0],
AUTHORITY[“EPSG”,“6258”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Geodetic longitude”, EAST],
AXIS[“Geodetic latitude”, NORTH],
AUTHORITY[“EPSG”,“4258”]],
PROJECTION[“Transverse_Mercator”, AUTHORITY[“EPSG”,“9807”]],
PARAMETER[“central_meridian”, 15.0],
PARAMETER[“latitude_of_origin”, 0.0],
PARAMETER[“scale_factor”, 0.9996],
PARAMETER[“false_easting”, 500000.0],
PARAMETER[“false_northing”, 0.0],
UNIT[“m”, 1.0],
AXIS[“Easting”, EAST],
AXIS[“Northing”, NORTH],
AUTHORITY[“EPSG”,“25833”]]
Bbox = ReferencedEnvelope[241429.08804878494 : 242285.88804878492, 5682820.523432539 : 5683607.323432539]
RemoteOwsType = null
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
BgColor = java.awt.Color[r=255,g=255,b=255]
Transparent = true
SldBody = null
ValidateSchema = false
Sld = null
SldVersion = null
TilesOrigin = null
Time =
Filter = null
Buffer = 0
Format = image/png
Filters = null
Get = true
RequestCharset = UTF-8
RawKvp = {BBOX=241429.08804878494,5682820.523432539,242285.88804878492,5683607.323432539, SERVICE=WMS, HEIGHT=1124, REQUEST=GetMap, STYLES=, WIDTH=1224, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1, FORMAT=image/png, GWC_SEED_INTERCEPT=true, LAYERS=lpt:Gebaeude, SRS=EPSG:25833}
BaseUrl = http://localhost:8080/geoserver/
Version = 1.1.1
Request = GetMap
Error: One factory fails for the operation “Mosaic”
Occurs in: org.geoserver.jai.ConcurrentOperationRegistry
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor124.invoke(Unknown Source)
at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
at org.geoserver.jai.ConcurrentOperationRegistry.invokeFactory(ConcurrentOperationRegistry.java:412)
at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
at javax.media.jai.RenderedOp.getSampleModel(RenderedOp.java:2233)
at org.geoserver.gwc.layer.GeoServerMetaTile.createTile(GeoServerMetaTile.java:170)
at org.geoserver.gwc.layer.GeoServerMetaTile.writeTileToStream(GeoServerMetaTile.java:82)
at org.geowebcache.layer.TileLayer.saveTiles(TileLayer.java:610)
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:500)
Caused by: java.lang.IllegalArgumentException: Alpha images must have the same sample size as the sources.
at com.sun.media.jai.opimage.MosaicOpImage.(MosaicOpImage.java:226)
at com.sun.media.jai.opimage.MosaicRIF.create(MosaicRIF.java:39)
… 24 more
18 Nov 11:47:57 INFO [seed.SeedTask] - Aborting seed thread GWC Seeder Thread-7. Error count reached configured maximum of 1000
FYI: Just upgraded to GeoServer 2.4.2, but the problem still prevails.
Von: Nachtigall, Jens (init) [mailto:Jens.Nachtigall@…5799…]
Gesendet: Montag, 18. November 2013 12:12
An: geoserver-users@lists.sourceforge.net
Betreff: [Geoserver-users] Seeding fails with “Alpha images must have the same sample size as the sources”
Dear all,
Best,
Jens
Request: getMap
Width = 1224
Height = 1124
Palette = null
Tiled = false
SRS = EPSG:25833
MaxFeatures = null
Exceptions = SE_XML
GEOGCS[“ETRS89”,
UNIT[“m”, 1.0],
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Time =
Filter = null
Buffer = 0
Format = image/png
Filters = null
Get = true
Version = 1.1.1
Request = GetMap
… 24 more
On Tue, Nov 19, 2013 at 3:32 PM, Nachtigall, Jens (init) <
By the looks of it, you're trying to seed a image mosaic layer, right?
One possible cause to the error message could be that the mosaic is made of
images that
are not uniform from the point of view of the color mode, for example, some
RGB, some
RGBA.
I don't believe we support this scenario.
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
HI Andrea,
Thanks for your reply. No, actually I am seeding a WMS layer. Quoting form first mail:
It works all well for seeding the first 3.5 GB of tiles (expecting about 50 GB in total), then it seems like a certain “mal-functioning” image is hit and tile processing is aborted.
Best, Jens
On Tue, Nov 19, 2013 at 3:32 PM, Nachtigall, Jens (init) <Jens.Nachtigall@anonymised.com> wrote:
By the looks of it, you’re trying to seed a image mosaic layer, right?
One possible cause to the error message could be that the mosaic is made of images that
are not uniform from the point of view of the color mode, for example, some RGB, some
RGBA.
I don’t believe we support this scenario.
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Nov 19, 2013 at 3:55 PM, Nachtigall, Jens (init) <
HI Andrea,
first mail:
Ouch, this makes it very difficult to debug, we have no way of reproducing
it.
You may want to open a ticket, but I'm afraid that without a direct
investigation on your servers (with full access and enough time
to spend on it) we'll have to wait for someone to stumble into the same
problem, but with an environment that makes
this easier to pinpoint and reproduce the issue.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
