[Geoserver-users] Serve crossdomain.xml from server root using Jetty
I have GeoServer running on Jetty, which when accessed from the outside has a url of http://www.example.com:8080/geoserver. The jetty.xml file uses the XML below to set up the server, and it works just fine. I need the server to return a crossdomain xml file from the following url http://www.example.com:8080/crossdomain.xml. After reading through the documentation, I believe I need to use either a Resource Handler, or a root-level context in order to serve this file, but I have been unable to determine the correct XML syntax to do so.
Any suggestions/examples of what needs to be added to the jetty.xml file below in order to have the crossdomain file served properly would be greatly appreciated.
Heather
--------------------------jetty.xml excerpt ------------------
/webapps
/etc/webdefault.xml
True
True
--------------------------end jetty.xml excerpt----------------------------
Hi Heather,
I tried various configurations of jetty.xml and could not get this to work... but I am far from an experienced jetty user. I suggest you ask on the jetty users list, you will get a better answer there.
-Justin
Heather
<Set name="handler">
      <New id="handlers" class="org.mortbay.jetty.handler.HandlerCollection">
        <Set name="handlers">
         <Array type="org.mortbay.jetty.Handler">
           <Item>
             <New id="contexts" class="org.mortbay.jetty.handler.ContextHandlerCollection"/>
           </Item>
           <Item>
             <New id="defaultHandler" class="org.mortbay.jetty.handler.DefaultHandler"/>
           </Item>
           <Item>
             <New id="requestLog" class="org.mortbay.jetty.handler.RequestLogHandler"/>
           </Item>
         </Array>
        </Set>
      </New>
    </Set>
    <!-- Discover contexts from webapps directory -->
    <Call class="org.mortbay.jetty.webapp.WebAppContext" name="addWebApplications">
      <Arg><Ref id="contexts"/></Arg>
      <Arg><SystemProperty name="jetty.home" default="."/>/webapps</Arg>
      <Arg><SystemProperty name="jetty.home" default="."/>/etc/webdefault.xml</Arg>
      <Arg type="boolean">True</Arg> <!-- extract -->
      <Arg type="boolean">True</Arg> <!-- parent priority class loading -->
    </Call>
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
