Thanks Jim I did not notice it was only going to you.
What I am trying to do is get a MOLA geotiff file from USGS converted to bil and downloaded into my WorldWind Android viewer. When I zoom in I am seeing terrain that looks broken up and spiky. I took Olympus Mons mountain and looked at the elevation data for several points on the mountain and noticed that the bil file when read for specific long/lat was negative for parts of the mountain. So that lead me to looking closer at the geoserver logs and the bil plugin settings. As I mentioned I looked at the geotiff using uDig and did notice the top of the mountain was very white and as I went to the base it got darker. Knowing the range of elevation for Mars went from 25k to -8k I wondered how the bil could show a -20k. So that makes me wonder about bil and settings to determine ranges.
Thanks for the help. I am doing this for kids.
-Tony
On Monday, February 1, 2016 3:06 PM, Jim Hughes jnh5y@anonymised.com wrote:
Tony,
I’m about to head out for the day; if you reply to the thread on the GeoServer list you might get some more feedback more quickly;)
What SRID/CRS is the input data in? If it is in 4326, then the error makes little sense…
Jim
On 02/01/2016 04:57 PM, Tony Anecito wrote:
Sure. Here is a typical request. I took it straight from the 2.6.2 log.
192.168.1.111 - - [01/Feb/2016:21:51:33 +0000] “GET /geoserver/wms?service=WMS&request=GetMap&version=1.1.1&crs=EPSG:4326&layers=sf:sfdem&styles=&format=application/bil16&width=150&height=150&bbox=-135.0,20.0,-130.0,25.0& HTTP/1.1” 200 45000
-Tony
On Monday, February 1, 2016 2:51 PM, Jim Hughes jnh5y@anonymised.com wrote:
Hi Tony,
Hmm… that’s interesting. I just wanted to make sure that you weren’t using 2.0.
If you provide a little more info on the list about how you made the request, etc. Others may be able to help out.
Jim
On 02/01/2016 04:10 PM, Tony Anecito wrote:
Hi Jim,
I am using 2.9 or at least that is what it says.
I will look at 2.8.2.Thanks!
-TonyOn Monday, February 1, 2016 12:48 PM, Jim Hughes jnh5y@anonymised.com wrote:
Hi Tony,
Are you actually using GeoServer 2.0? If so, updating may be the first
thing to try.Particularly, I’d suggest trying things out with GeoServer 2.8.2 (latest
stable) and grabbing the extension from here:
http://ares.boundlessgeo.com/geoserver/2.8.x/community-latest/.I’m surprised that the stack trace doesn’t go through the community
package name (org.geoserver.wms.worldwind). Are you trying to export
the data as BIL or DDS?Thanks,
Jim
p.s. Community modules are supported by the community. I’ve never used
this plugin; I am mildly interested since the error relates to bad
matrix algebra.On 02/01/2016 02:05 PM, adanecito wrote:
Hi All,
I noticed the following exception is in the log of my geoserver 2.0 server.
It seems to be related to a getMap request but no info on what exactly is
the root cause. I am sorry I am posting since the the exception is quite
long. The getMap request is for the bil plugin.Any clue to this mystery or next step to try is appricated.
-Tony
org.geoserver.platform.ServiceException: Error rendering coverage on the
fast path
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:346)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:261)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:131)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:505)
at org.geoserver.wms.GetMap.run(GetMap.java:249)
at org.geoserver.wms.GetMap.run(GetMap.java:119)
at
org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:320)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at
org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at
org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:74)
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at
at
org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at
at
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at com.sun.proxy.$Proxy61.getMap(Unknown Source)
at
at
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:847)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:275)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:933)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:867)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:953)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:844)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:829)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at
org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at
at
at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at
at
at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:343)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:260)
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at
at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:106)
at
at
org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at
org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at
org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at
org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at
org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at
org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at
org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at
org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
at
org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:110)
at
org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
at
org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at
org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at
org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at
org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.geoserver.platform.ServiceException:
java.lang.IllegalArgumentException: Illegal transform of type
“AffineTransform2D”.
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1083)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:344)
… 112 more
Caused by: java.lang.IllegalArgumentException: Illegal transform of type
at
org.geotools.coverage.grid.GridGeometry2D.inverse(GridGeometry2D.java:646)
at
org.geotools.coverage.grid.GridGeometry2D.(GridGeometry2D.java:491)
at
org.geotools.coverage.grid.GridGeometry2D.(GridGeometry2D.java:474)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.computeReadingGeometry(GridCoverageReaderHelper.java:417)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverageInEnvelope(GridCoverageReaderHelper.java:291)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverages(GridCoverageReaderHelper.java:204)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:800)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:768)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:975)
… 113 more
Caused by:
org.opengis.referencing.operation.NoninvertibleTransformException:
Determinant is 0
at
org.geotools.referencing.operation.transform.AffineTransform2D.inverse(AffineTransform2D.java:193)
at
org.geotools.coverage.grid.GridGeometry2D.inverse(GridGeometry2D.java:644)
… 121 more
Caused by: java.awt.geom.NoninvertibleTransformException: Determinant is 0
at java.awt.geom.AffineTransform.createInverse(AffineTransform.java:2706)
at
org.geotools.referencing.operation.transform.AffineTransform2D.inverse(AffineTransform2D.java:189)
… 122 more–
View this message in context: http://osgeo-org.1560.x6.nabble.com/Server-error-for-getMap-request-tp5248360.html
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
Geoserver-users@anonymised.comsourceforge.net
Geoserver-users@anonymised.comrceforge.net
