[Geoserver-users] Serving a large number of Geotiffs
If you want to keep all 60000 layers which is not optimal as Andrea just wrote, the most obvious thing to do is to create overviews for the images.
gdaladdo –r average 2 4 8 16 32 64 image.tif --config COMPRESS_OVERVIEW DEFLATE
It is worth making a test before reprojecting images physically into EPSG:3857. On-the-fly reprojecting is not necessarily so slow.
I saw that you have used the BIGTIFF=YES option. It is not needed for your small images and it probably makes reading the images a little bit slower but I guess that the difference is marginal. Tile size 256x256 could be a bit faster than 512x512 but that’t also marginal.
-Jukka Rahkonen-
basiliosz wrote:
As 60000 layers. They are not contiguous, are completely separate and are viewed strictly one at a time per user.
The scenario: user selects a city and a couple parameters, the JS code figures out what layer to request, then submits the request for that layer to Geoserver. Eventually the layer is added to the map.
Max
On 17 Mar 2016 13:44, “Andrea Aime” <andrea.aime@…1107…> wrote:
just to be sure, how have you published them?
As a single image mosaic or as 60000 separate layers?
On Thu, Mar 17, 2016 at 12:56 PM, Max <basiliosz@…84…> wrote:
Thanks - because of the origin of the data the Geotiffs are not
adjacent, there’s a little group for each of about 500 cities, but
strictly one of them at a time is shown, so I’m not sure how much
that’s going to help. If there’s something computationally intensive
going on at the server’s end, that’s going to be a drag in any case.
Going through the Geoserver on Steroids presentation now, thanks!
Max
On 17 March 2016 at 11:16, Ian Turton <ijturton@…84…> wrote:
Those sound like small tiffs so you would be better combining them together
to avoid opening too many files at a time. Have a look at gdalbuildvrt to
make a virtual raster catalogue that you can then convert into a tiled
compressed geotiff that is in your main output projection.
Have a read through the annual “GeoServer on Steroids” presentation
(http://www.slideshare.net/geosolutions/geoserver-on-steroids-foss4g-2015 )
for more ideas.#
Ian
On 17 March 2016 at 09:51, Max <basiliosz@…84…> wrote:
I have a large number - more than 60 thousand - of relatively small
Geotiffs, usually from 2 to 12 Mb. I have a web client that uses
Leaflet to view them, but things are quite slow even inside our own
network. I have a hunch that both Geoserver and these Geotiffs are not
configured in the best way possible.
The tiffs were generated from a bunch of EPSG:3035 Ascii grid files
using this command:
for f in *.rsl; do gdal_translate -a_srs EPSG:3035 -co “TILED=YES”
-co “BLOCKXSIZE=512” -co “BLOCKYSIZE=512” -co “COMPRESS=DEFLATE” -co
“ZLEVEL=9” -co “BIGTIFF=YES” $f $f.tif; done
Then I wrote a Python script that created a store and a layer for each
of the tiffs.
Here is the output from gdalinfo for a typical one:
Driver: GTiff/GeoTIFF
Files: se502c_R9_C1_3_T_2531_sec.rsl.tif
Size is 3396, 2271
Coordinate System is:
PROJCS[“ETRS89 / LAEA Europe”,
GEOGCS[“ETRS89”,
DATUM[“European_Terrestrial_Reference_System_1989”,
SPHEROID[“GRS 1980”,6378137,298.2572221010002,
AUTHORITY[“EPSG”,“7019”]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY[“EPSG”,“6258”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4258”]],
PROJECTION[“Lambert_Azimuthal_Equal_Area”],
PARAMETER[“latitude_of_center”,52],
PARAMETER[“longitude_of_center”,10],
PARAMETER[“false_easting”,4321000],
PARAMETER[“false_northing”,3210000],
As you can see they are EPSG:3035. They should be internally tiled. In
the Coordinate Reference Systems for Geoserver, it says that both
Native SRS and Declared SRS are EPSG:3035, and that the handling
should be to reproject native to declared.
My web client overlays these Geotiffs on a standard OpenStreetMap
layer in Web Mercator. All the geotiffs we have tried appear
correctly, so I guess reprojection is still happening at some stage.
My gut feeling is that I might gain some speed by reprojecting the
original Geotiffs to Web Mercator, or at least changing the declared
SRS to Web Mercator in Geoserver. Not keen on it, it’s going to take
days. What other properties of the Geotiffs could I tinker with?
Would caching with GeoWebCache help, given the file size?
Bonus question - if a Geotiff is changed, by reprojecting or retiling
or what have you, does the Geoserver layer associated with it get
invalidated? It took days to create them all.
I’d really appreciate your feeback.
Thanks in advance,
Max
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
Geoserver-users mailing list
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
If I create overviews for the images, do the Geoserver layers
associated with it need to be recreated?
Max
On 17 March 2016 at 14:21, Rahkonen Jukka (MML)
<jukka.rahkonen@anonymised.com> wrote:
DEFLATE
-Jukka Rahkonen-
Max
On 17 Mar 2016 13:44, "Andrea Aime" <andrea.aime@anonymised.com> wrote:
adjacent, there's a little group for each of about 500 cities, but
strictly one of them at a time is shown, so I'm not sure how much
that's going to help. If there's something computationally intensive
going on at the server's end, that's going to be a drag in any case.
Max
together
Have a read through the annual "GeoServer on Steroids" presentation
for more ideas.#
Ian
using this command:
for f in *.rsl; do gdal_translate -a_srs EPSG:3035 -co "TILED=YES"
-co "BLOCKXSIZE=512" -co "BLOCKYSIZE=512" -co "COMPRESS=DEFLATE" -co
"ZLEVEL=9" -co "BIGTIFF=YES" $f $f.tif; done
of the tiffs.
Size is 3396, 2271
PROJCS["ETRS89 / LAEA Europe",
    GEOGCS["ETRS89",
        DATUM["European_Terrestrial_Reference_System_1989",
            SPHEROID["GRS 1980",6378137,298.2572221010002,
                AUTHORITY["EPSG","7019"]],
        AUTHORITY["EPSG","6258"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4258"]],
    PROJECTION["Lambert_Azimuthal_Equal_Area"],
    PARAMETER["latitude_of_center",52],
    PARAMETER["longitude_of_center",10],
    PARAMETER["false_easting",4321000],
    PARAMETER["false_northing",3210000],
SRS to Web Mercator in Geoserver. Not keen on it, it's going to take
I'd really appreciate your feeback.
Thanks in advance,
Max
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
Going by memory, to be sure the overviews are recognized, you have to
restart
the server, or reload the configuration (the reload button in the server
configuration panel)
Ing. Andrea Aime
@geowolf
Technical Lead
