there is not such a thing as a DEM format, DEM refers to the nature of the data,
digital elevation model, not to how it’s encoded in a file format (it’s like saying
“I have a satellite image” without saying if it’s geotiff, jpeg2000, ecw, and so on).
Looking at a few a random DEMs in that collection, it seems they are in
ESRI Arc ASCII format:
http://www.ngdc.noaa.gov/dem/squareCellGrid/download/393
If that’s the case, GeoServer should be able to open them as ASCII ArcGrid,
you can try it out, but I would not recommend using that format for serving the file, it’s a text
format without overviews, so it’s bound to be slower than other alternatives.
If you want to serve it out with good performance, I’d recommend to use gdal_translate
and gdaladdo to turn it into a geotiff with overviews instead
On Thu, Feb 4, 2016 at 8:28 AM, Bulent Ozhorasan <bozhorasan@anonymised.com> wrote:
Greetings,
I’m using Geoserver 2.8.1.
I have downloaded DEM package from http://www.ngdc.noaa.gov/dem/squareCellGrid/search site
Which option should I select from Raster Data Sources to publish it as a WMS layer?
or is there a plugin for DEM? In extensions page I haven’t seen an item related with DEM
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
