[Geoserver-users] serving huge raster datasets with GeoServer
Dear friends,
I am new to GeoServer and just started to explore the coverage serving
capabilities, and would like to have your suggestions and ideas on how
to proceed. I have already read the posts in GeoServer User
documentation, mainly
http://geoserver.org/display/GEOSDOC/High+performance+coverage+serving
but I still have some questions, especially since that text was
written half a year ago.
We have currently 8.6 gb of aerial photography in GeoTIFF format,
which we want to put online with GeoServer. In total there are 77
individual mosaic tiles processed and mosaiced with OrthoVista
software, each having the same filesize of 118 mb. We have also the
same dataset in ECW format, while compressed the total filesize drops
to 248 mb but the visual quality is still acceptable for our purposes.
Our aim is to share these coverages as a background layer, and on top
of it will be overlaid vector layers: building footprints, road
network, and some administrative boundaries. The data will be
displayed with OpenLayers on custom-made clients, and even on web
browsers. The imagery will be not used for analysis, so even heavily
compressed imagery (ECW, JPEG2000) would suffice, but then there is
the question of how much time the decompressing of imagery will take
upon every request?
The GeoServer will we running in a closed Intranet, which is quite
slow Wireless network since we are based on a developing country. What
is needed is as fast display of the imagery as possible, so the ECW
would perhaps be the optimal choice. But I am not sure if it is
possible to serve ECW with GeoServer, even with the ImageIO-ext GDAL
extension?
Some general questions:
- Is it better to use compressed or decompressed imagery with these
kind of huge datasets?
- LZ77 compression vs uncompressed TIFF images
- Individual mosaic tiles vs. mosaicked single image
- Can GeoServer read pyramid layers (.rrd) made with ArcGIS or Erdas
Imagine, or do I have to create them with gdal?
- If ECW is not possible, any suggestions for other formats? JPG2000 or MrSID?
Below is some info about our original, uncompressed GeoTIFF imagery:
C:\gdal\bin>gdalinfo e:\tif\520_9320.tif
Driver: GTiff/GeoTIFF
Files: e:\tif\520_9320.tif
       e:\tif\520_9320.aux
Size is 6250, 6250
Coordinate System is `'
Origin = (520000.000000000000000,9321000.000000000000000)
Pixel Size = (0.160000000000000,-0.160000000000000)
Metadata:
  TIFFTAG_SOFTWARE=OrthoVista
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 520000.000, 9321000.000)
Lower Left ( 520000.000, 9320000.000)
Upper Right ( 521000.000, 9321000.000)
Lower Right ( 521000.000, 9320000.000)
Center ( 520500.000, 9320500.000)
Band 1 Block=128x128 Type=Byte, ColorInterp=Red
  Min=0.000 Max=255.000
  Minimum=0.000, Maximum=255.000, Mean=100.007, StdDev=34.047
  Overviews: 1024x1024
  Metadata:
    STATISTICS_MINIMUM=0
    STATISTICS_MAXIMUM=255
    STATISTICS_MEAN=100.007484672
    STATISTICS_MEDIAN=0
    STATISTICS_MODE=1.7884416006343e-299
    STATISTICS_STDDEV=34.047496023691
    LAYER_TYPE=athematic
<GDALRasterAttributeTable/>
Band 2 Block=128x128 Type=Byte, ColorInterp=Green
  Minimum=0.000, Maximum=255.000, Mean=121.846, StdDev=37.349
  Metadata:
    STATISTICS_MEAN=121.8462572288
    STATISTICS_MEDIAN=0
    STATISTICS_MODE=1.8047999164279e-299
    STATISTICS_STDDEV=37.348685345109
Band 3 Block=128x128 Type=Byte, ColorInterp=Blue
  Minimum=0.000, Maximum=255.000, Mean=135.154, StdDev=40.212
  Metadata:
    STATISTICS_MEAN=135.154277504
    STATISTICS_MEDIAN=0
    STATISTICS_MODE=1.8111374963437e-299
    STATISTICS_STDDEV=40.211793313468
Many thanks in advance for any advice!
Pekka Hurskainen
SMOLE
Zanzibar, Tanzania
pekka.hurskainen@anonymised.com
Hi Pekka,
GeoServer can handle ECW files but of course you need to buy a valid
license in order to use the ECW Decoder in a server fashion
architecture.
Anyway, imho you can still successfully use your GeoTIFF files with
good performances by adopting few expedients like:
1. Applying overviews to your GeoTIFFs
2. Tilize your GeoTIFFs
4. Serve the maps as GIF files and applying palettes if the number of
colors is limited or serve the maps as PNG-8
About the compressed vs. uncompressed questions, if you have a good
server and use the hints above you shouldn't notice particular leaks
of performances.
Mr.Sid are of course much slower than the other formats.
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584 980933
fax: +39 0584 983027
mob: +39 349 8227000
On Fri, Jan 9, 2009 at 10:49 AM, Pekka Hurskainen
<pekka.hurskainen@anonymised.com> wrote:
Dear friends,
upon every request?
extension?
      e:\tif\520_9320.aux
Size is 6250, 6250
Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Metadata:
   STATISTICS_MEDIAN=0
Metadata:
   STATISTICS_MEDIAN=0
Metadata:
   STATISTICS_MEDIAN=0
Pekka Hurskainen
SMOLE
Zanzibar, Tanzania
Check out the new SourceForge.net Marketplace.
It is the best place to buy or sell services for
just about anything Open Source.
http://p.sf.net/sfu/Xq1LFB
Geoserver-users mailing list
Pekka,
We're doing something similar, and I've gotten reasonable results with GeoTIFF, Jpeg compressed, YCBCR, followed by creating overviews
Gdal_Translate -co compress=jpeg -co photometric=YCBCR -co tiled=yes infile outfile
then
GdalAddo -r gauss --config INTERLEAVE_OVERVIEW PIXEL --config COMPRESS_OVERVIEW JPEG filename 2 4 8 16 32 64
Then using the image mosaic in GeoServer.
Sizes approach that of the original mrSid, but way better performance.
If you look in the Gdal GeoTIFF docs, it mentions how YCBCR makes for better compression (2-3x) than normal RGB.
As far as performance, I've seen in the past that a fast processor doing a simple (jpeg) decompression can often outrun accessing an uncompressed image from disk.
Roger
From: "Pekka Hurskainen" <pekka.hurskainen@anonymised.com>
Sent: Friday, January 09, 2009 10:49 AM
To: <geoserver-users@lists.sourceforge.net>
Subject: [Geoserver-users] serving huge raster datasets with GeoServer
Dear friends,
upon every request?
extension?
      e:\tif\520_9320.aux
Size is 6250, 6250
Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Metadata:
   STATISTICS_MEDIAN=0
Metadata:
   STATISTICS_MEDIAN=0
Metadata:
   STATISTICS_MEDIAN=0
Pekka Hurskainen
SMOLE
Zanzibar, Tanzania
As others already have pointed out, you should look into using cached tiles, probably stored as JPEGs so that you don't have to do any more work before sending them to the client. Assuming you can get your data into GeoServer, the only requirement is additional disk space.
GeoServer 1.7.1 includes GeoWebCache; Just configure your layer, restart GeoServer and go to http://localhost:8080/geoserver/gwc
You should find your layer in the list, using PNG by default. Just append &format=image/jpeg to the URL.
If you need projections other than EPSG:4326 and EPSG:900913 you can add them by creating a configuration file <GEOSERVER DATA DIR>/gwc/geowebcache.xml
-Arne
Pekka Hurskainen wrote:
Dear friends,
upon every request?
extension?
       e:\tif\520_9320.aux
Size is 6250, 6250
Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
  Metadata:
    STATISTICS_MEDIAN=0
  Metadata:
    STATISTICS_MEDIAN=0
  Metadata:
    STATISTICS_MEDIAN=0
Pekka Hurskainen
SMOLE
Zanzibar, Tanzania
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
Thank you so much for your valuable advice and sorry for keeping quiet
so long. I have been quite busy trying to implement what you have
suggested and after a lot of set-backs I think I have finally managed
to get there.
What I have done so far:
1) Compressed the original GeoTIFF files into JPEG, YCM
-Arne
Dear friends,
upon every request?
extension?
MrSID?
      e:\tif\520_9320.aux
Size is 6250, 6250
Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Metadata:
   STATISTICS_MEDIAN=0
Metadata:
   STATISTICS_MEDIAN=0
Metadata:
   STATISTICS_MEDIAN=0
Pekka Hurskainen
SMOLE
Zanzibar, Tanzania
Arne Kepp
Pekka Hurskainen
+358-44-3390018
Whoops, pressed the send button accidently too soon, sorry for that.
To continue where I left:
1) Compressed the original GeoTIFF files into JPEG, YCBCR tiles and
created the overlays as Roger suggested
2) Created a mosaic with the ImageMosaic plugin and loaded the data
into GeoServer as Roger suggested
3) Installed and configured GeoWebCache (.war file) as suggested by
Arne, which took a lot of time and trials & errors, and a lot of
studying
4) Installed native JAI libraries for JRE, since I got error messages
from Tomcat of not having it
5) Configured Apache Tomcat to deal with memory issues
(Java.lang.outofmemoryerror: Java Heap space) as instructed in
http://geoserver.org/display/GEOSDOC/2.6+GeoServer+in+Production+Environment
I used to get a lot of trouble with points 4 and 5 when trying to view
my mosaic through the gwc demo page in my web browser, with always the
same problem of some tiles at some scales not showing up at all and
some tiles getting all red and showing the
"Java.lang.outofmemoryerror: Java Heap space" error. I did everything
as instructed, but still got the same problems. Finally I realised I
must empty my web browser's cache, and after that everything worked
smoothly and fast!
My only question, at least for now, is can I get GeoWebCache on
GeoServer to work with ArcGIS 9.3 as a tiled WMS service? I could
connect to GeoServer and get my mosaic as a normal WMS layer, but when
I defined http://dbs:8080/geoserver/gwc/service/wms? to the server URL
in ArcCatalog, I can get a list of all my layers but nothing can be
seen either on the preview tab nor on ArcMap. So I guess this is not
implemented? It is not a big thing, since I can still use the normal
un-cached WMS service for ArcMap use, but getting GWC to work would be
better of course.
Thanks again for your help! I really appreciate how active and helpful
the GeoServer community is.
-Pekka
On Mon, Jan 19, 2009 at 3:22 PM, Pekka Hurskainen
to get there.
-Arne
Dear friends,
upon every request?
extension?
MrSID?
      e:\tif\520_9320.aux
Size is 6250, 6250
Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Metadata:
   STATISTICS_MEDIAN=0
Metadata:
   STATISTICS_MEDIAN=0
Metadata:
   STATISTICS_MEDIAN=0
Pekka Hurskainen
SMOLE
Zanzibar, Tanzania
Arne Kepp
Sorry about that, you are right that current version of GeoWebCache / GeoServer will cache error messages too (it cannot tell them apart). We recently did some work on this, I must double check whether everything is in place to detect this.
I am guessing that ArcCatalog is using the getcapabilities document. With the integrated version of GeoServer this may actually work, thanks to a hack / patch by Jody Garnett. The freestanding version (WAR) of GWC is currently not able to provide a getcapabilities response.
If you can configure the layers individually in arccatalog then you should be able to get past this. I'm not sure exactly when we'll have a proper getcapabilties document, it would require users to provide a somewhat more extensive configuration to satisfy the WMS standard.
Anyway, glad it's smooth and fast at least :wink:
-Arne
studying
smoothly and fast!
better of course.
-Pekka
to get there.
-Arne
Dear friends,
upon every request?
extension?
MrSID?
      e:\tif\520_9320.aux
Size is 6250, 6250
Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Metadata:
   STATISTICS_MEDIAN=0
Metadata:
   STATISTICS_MEDIAN=0
Metadata:
   STATISTICS_MEDIAN=0
Pekka Hurskainen
SMOLE
Zanzibar, Tanzania
Arne Kepp
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
Arne Kepp
