[Geoserver-users] Serving Raster using GDAL with GeoServer
I have trouble to serve raster through GDAL extension with GeoServer. I tried the same raster with ERDAS img and ArcGrid formats. Both of them were displayed correctly in ArcMap and can be gdalinfo on the server hosting GeoServer. However, neither of them worked with GeoServer. Adding them to GeoServer stores always cause problems.
OS: CentOS 5
JRE: 6.0_39-b04
Java VM: Java HotSpot™ 64-Bit Server VM
Application Server: Tomcat 6 with APR
GeoServer: 2.2.4 with GDAL extension
GDAL: 1.9.2 libgdaljni*.so was copied to APR lib folder so Tomcat can see them
Checking Tomcat log: Feb 19, 2013 11:29:35 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
INFO: GDAL Native Library loaded (version: 1.9.2)
It appears GDAL extension was loaded correctly and all “GDAL format” show up on GUI. If ERDAS image was given, a Java Runtime Error (SIGSEGV, write to invalid address probably) will occur in JVM and Tomcat will be restarted. Trackback to Java Frame, what on top is:
j org.gdal.gdal.gdalJNI.MajorObject_GetMetadata_List__SWIG_0(JLorg/gdal/gdal/MajorObject;Ljava/lang/String;)Ljava/util/Vector;+0
If dataset folder for AIG is given, GeoServer can’t pick it up. So, hdr.adf in the folder was fed to Geoserver, the same error above will happen again.
I wonder if there is anything I missed? Should I just use the binary along with the gdal extension instead? That doesn’t sound nice…
Thanks a lot!
Guan
Hi Guan,
can you try extracting all the GDAL related .so (*jni.so and *.so core libs) on your jre/lib/amd64 folder and see if things are working better?
Please, let me know.
Best Regards,
Daniele
On Tue, Feb 19, 2013 at 7:37 PM, Guan Wang <gwang@anonymised.com> wrote:
OS: CentOS 5
JRE: 6.0_39-b04
Thanks a lot!
Guan
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_feb
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Hi Daniele,
I apologize for the long wait. :slight_smile:
Tried with your suggestion but got the same java Runtime error. Are there
any other things I could try?
Guan
  _____
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of
Daniele Romagnoli
Sent: Monday, February 25, 2013 3:11 AM
To: gwang@anonymised.com
Subject: Re: [Geoserver-users] Serving Raster using GDAL with GeoServer
Hi Guan,
Best Regards,
Daniele
OS: CentOS 5
JRE: 6.0_39-b04
Java VM: Java HotSpot(TM) 64-Bit Server VM
them
It appears GDAL extension was loaded correctly and all "GDAL format" show up
j
If dataset folder for AIG is given, GeoServer can't pick it up. So, hdr.adf
with the gdal extension instead? That doesn't sound nice.
Thanks a lot!
Guan
information.
