[Geoserver-users] Serving tiled heatmaps
Is it possible to render transformation (in my case, heatmaps) and serve them tiled through WMS? I’m using the example from http://docs.geoserver.org/stable/en/user/styling/sld-extensions/rendering-transform.html, but down the page it says:
Rendering transformations may not work correctly in tiled mode, unless they >have been specifically written to accomodate it.
I tried with Leaflet.js and had to use a custom layer*[0] to make it render without glitches, although it still doesn’t render the like the original image.
I wish I could just use the default Leaflet WMS API*[1], but apparently it’s not possible. Does anyone know if it’s possible somehow? The ntoe says “unless it has been specifically written to accomodate it”, what does it mean exactly?
Thanks!
– Marcelo.
*[0] https://github.com/ismyrnow/Leaflet.singletilewms
bump
I just would like to know how to render the rendering transformation as tiles. Does anyone know?
Thanks!
On Wed, Jul 22, 2015 at 8:28 PM, Marcelo de Moraes Serpa <celoserpa@anonymised.com> wrote:
Thanks!
– Marcelo.
On Mon, Jul 27, 2015 at 11:58 PM, Marcelo de Moraes Serpa <
*bump*
Some rendering transformations are built to be tiled, some are not.
The heatmap one is definitely not, the algorithm currently implemented
makes no sense when tiled (as it changes
the output taking into account everything in the requested bounding box,
and if you slice it, you change
the input data).
If what you want to depict is not point density, but some representation of
one of their attributes,
you might want to try the Barnes surface interpolation... while I have no
experience with it,
by a quick look at the code, it seems it might tile correctly (at least,
there seems to be some
effort in that direction in the code, no idea if it works)
The process has never been documented in GeoServer docs by its original
author (Martin Davis),
but there is something lying around in the net:
http://lin-ear-th-inking.blogspot.it/2012/02/barnes-analysis-for-surface.html
http://suite.opengeo.org/4.1/cartography/rt/barnes.html
If this is not what you're looking for, rendering transformations are
pluggable, so you can
either write your own, or have someone write it for you, see
http://geoserver.org/support/
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
My main GeoServer server has become corrupted.
Our IT people want me to rebuild the server but would prefer I use Windows Server 2012 rather than the current Windows Server 2008 R2
Are there any known issues using Apache Tomcat and the War version of GeoServer with Windows Server 2012 ?
I will be installing 2.7.1.1 as 2.7.2 is missing from the sourceforge.net server
Mark Ismail
Principal IT Officer
Tel: 0151 443 3021
Knowsley Council ê Westmorland Road ê Huyton ê L36 9GL
Save time – use the IT Service Desk Self Serve Application
Hi Mark,
I’d be surprised if there were issues.
A quick google indicates others have done it:
i.e.
http://boundlessgeo.com/2013/03/how-to-publish-gdalmrsid-image-formats-on-a-production-geoserver-on-windows/
http://sourceforge.net/p/geoserver/mailman/message/33104731/
There are no obvious threads jumping out that things were going horribly wrong.
Of course, my one experience with Server 2012 left me wondering how to use the UI (good luke finding “log-off” J ), but that’s not a GeoServer problem.
Jonathan
Sent: Tuesday, July 28, 2015 10:05 AM
To: GeoServer Mailing List List
Subject: [Geoserver-users] Geoserver WAR version and windows server 2012
Mark Ismail
Tel: 0151 443 3021
This e-mail and any attachments are confidential. It may contain privileged information and is intended for the named recipient(s) only. It must not be distributed without consent. If you are not one of the intended recipients, please notify the sender immediately and do not disclose, distribute, or retain this email or any part of it and do not take any action based on it.
Unless expressly stated, opinions in this email are those of the individual sender, and not of Knowsley MBC. Legally binding obligations can only be created for, or be entered into on behalf of, Knowsley MBC by duly authorised officers or representatives.
Knowsley MBC excludes any liability whatsoever for any offence caused, any direct or consequential loss arising from the use, or reliance on, this e-mail or its contents. We believe but do not warrant that this e-mail and any attachments are virus free. You must therefore take full responsibility for virus checking and no responsibility is accepted for loss or damage arising from viruses or changes made to this message after it was sent. Knowsley MBC reserves the right to monitor and/or record all e-mail communications through its network in accordance with relevant legislation.
This message has been scanned for viruses by MailControl, a service from BlackSpider Technology
Click here to report this email as spam.
One thing, do not upgrade Tomcat to version 8, it was made incompatible with apps using JAI ImageIO.
Still have to figure out exactly what happened before we open a bug report against Tomcat
On Tue, Jul 28, 2015 at 4:15 PM, Jonathan Moules <J.Moules@anonymised.com> wrote:
Hi Mark,
i.e.
Jonathan
From: Ismail, Mark [mailto:mark.ismail@anonymised.com]
Mark Ismail
Tel: 0151 443 3021
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Had some success it all seemed to work fine until I added this to web.xml like I normally do:-
GEOSERVER_DATA_DIR
C:\GeoData
Then Tomcat can’t start geoserver
I suspect its something to do with permissions on the folder, so I mirrored what was on the 2008 R2 box but no luck
Mark Ismail
geoserver log snippet.txt (44.3 KB)
From: andrea.aime@…84… [mailto:andrea.aime@…84…] On Behalf Of Andrea Aime
Sent: 28 July 2015 15:25
To: Jonathan Moules
Cc: Ismail, Mark; List
Subject: Re: [Geoserver-users] Geoserver WAR version and windows server 2012
On Tue, Jul 28, 2015 at 4:15 PM, Jonathan Moules <J.Moules@…6706…> wrote:
Hi Mark,
i.e.
Jonathan
Mark Ismail
Tel: 0151 443 3021
Ing. Andrea Aime
@geowolf
Technical Lead
By looking at the logs, it kind of seems GeoServer is missing the
plugin providing the store you were using.
If it’s the case of Oracle, recent versions of GeoServer stopped shipping
the JDBC driver because of redistribution restrictions, did you add
the JDBC driver manually in the WEB-INF/lib manually?
On Wed, Jul 29, 2015 at 10:31 AM, Ismail, Mark <mark.ismail@anonymised.com> wrote:
GEOSERVER_DATA_DIR
C:\GeoData
Mark Ismail
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
To: Jonathan Moules
On Tue, Jul 28, 2015 at 4:15 PM, Jonathan Moules <J.Moules@anonymised.com…> wrote:
Hi Mark,
i.e.
Jonathan
Mark Ismail
Tel: 0151 443 3021
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
I copied the ojdbc7.jar and gt-jdbc-oracle-13.1.jar into the lib folder ( I also tried it with ojdbc6.jar)
I moved my data from c:\geodata into the default folder and its still failing
I also tried 64 bit versions of the jre and apache tomcat again with no luck
I did search the log for ERROR rather than warn and found this :-
2015-07-29 10:13:18,310 ERROR [data.shapefile] - The following locker still has a lock: read on file:/C:/GeoData/coverages/mosaic_sample/mosaic.shp by org.geotools.data.shapefile.shp.ShapefileReader
Mark Ismail
Tel: 0151 443 3021
Sent: 29 July 2015 09:52
To: Ismail, Mark
Cc: List
GEOSERVER_DATA_DIR
C:\GeoData
Mark Ismail
To: Jonathan Moules
Hi Mark,
i.e.
Jonathan
Mark Ismail
Tel: 0151 443 3021
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jul 29, 2015 at 11:53 AM, Ismail, Mark <mark.ismail@anonymised.com>
failing
Failing in the same way? Do you have the logs?
Ing. Andrea Aime
@geowolf
Technical Lead
I wiped my logs and it created a log small enough to send
Mark Ismail
geoserver.log (68.4 KB)
Sent: 29 July 2015 11:10
To: Ismail, Mark
Cc: List
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jul 29, 2015 at 12:13 PM, Ismail, Mark <mark.ismail@anonymised.com>
One line, two things:
2015-07-29 11:08:44,138 INFO [geoserver.global] - Falling back to embedded
data directory: C:\Program Files\Apache Software Foundation\Tomcat
8.0\webapps\geoserver\data
1) It seems it's not using your external data directory
2) It's Tomcat 8, which is known not to work, I did say so earlier in this
thread
Ing. Andrea Aime
@geowolf
Technical Lead
I copied my data into the internal folder to try remove that as a possible reason
I’ve been using Tomcat 8.15 to 8.21 for 6 months with no issues on windows server 2008 – my backup server is currently running on 8.21 with the same data with no problems
I can try Tomcat 7 if that is what will work with windows server 2012
Mark Ismail
Sent: 29 July 2015 11:16
To: Ismail, Mark
Cc: List
2015-07-29 11:08:44,138 INFO [geoserver.global] - Falling back to embedded data directory: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data
  1. It seems it’s not using your external data directory
  2. It’s Tomcat 8, which is known not to work, I did say so earlier in this thread
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jul 29, 2015 at 12:24 PM, Ismail, Mark <mark.ismail@anonymised.com>
possible reason
Interesting, we have had some reports of Tomcat 8 not working, and indeed
it's not working on my computer either:
https://osgeo-org.atlassian.net/browse/GEOS-7122
But it's Tomcat 8.0.24, so maybe it's a recent regression? Don't think the
issue would be platform dependent (I'm on Linux)
So now I don't see any other error in your logs, so what is not working?
Did you check if the stores/layers that are not working are by any chance
not enabled anymore?
Ing. Andrea Aime
@geowolf
Technical Lead
We have done a bit more investigation here and it seems the issue may be postgis related
The postgis server log is reporting :-
2015-07-29 10:13:41 BST LOG could not receive data from client: No connection could be made because the target machine actively refused it.
I have our server guys trying to find why its happening
Mark Ismail
Sent: 29 July 2015 11:31
To: ‘Andrea Aime’
Cc: List
Mark Ismail
To: Ismail, Mark
Cc: List
Ing. Andrea Aime
@geowolf
Technical Lead
Did you change your server IP address? if so you may have to reopen access to PostGIS using the new IP.
Ian
On Wed, Jul 29, 2015 at 12:10 PM Ismail, Mark <mark.ismail@anonymised.com> wrote:
Mark Ismail
To: ‘Andrea Aime’
Cc: List
Mark Ismail
From: andrea.aime@anonymised.com… [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
To: Ismail, Mark
Cc: List
On Wed, Jul 29, 2015 at 12:13 PM, Ismail, Mark <mark.ismail@anonymised.com440…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
IP Address did change but I give postgis access to all pc in our domain who give the correct password
Mark Ismail
Sent: 29 July 2015 13:37
To: Ismail, Mark; Andrea Aime
Cc: List
Ian
Mark Ismail
To: ‘Andrea Aime’
Cc: List
Mark Ismail
To: Ismail, Mark
Cc: List
Ing. Andrea Aime
@geowolf
Technical Lead
Check the rights in your Folder:
C:\Windows\TEMP
I had the problems with 2008R2 too.
Give Read and Wright (RW) rights to the System, User xXx
Mit freundlichen Grüßen
Im Auftrag
Michael Räder
Michael Räder
Nationalpark-Verwaltung Niedersächsisches Wattenmeer
Virchowstr. 1 / 26382 Wilhelmshaven
Tel.: +49 (0) 4421 911 295 / Fax.: +49 (0) 4421 911 280
Email: michael.raeder@…4125…
[MDI - NI][NLPV][MDI - DE]
Von: Ismail, Mark [mailto:mark.ismail@…6440…]
Gesendet: Mittwoch, 29. Juli 2015 15:25
An: ‘Ian Turton’; Andrea Aime
Cc: List
Betreff: Re: [Geoserver-users] Geoserver WAR version and windows server 2012
Mark Ismail
Cc: List
Ian
Mark Ismail
To: ‘Andrea Aime’
Cc: List
Mark Ismail
To: Ismail, Mark
Cc: List
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea, thanks for replying!
Regarding generating the actual layer, do you think it’d be better to pre-generate it using tools like GMT, GRASS or GDAL and then just tile the image using WMS or dynamically generate it by applying a SLD style to the vector data?
– Marcelo.
On Tue, Jul 28, 2015 at 1:01 AM, Andrea Aime <andrea.aime@anonymised.com7…> wrote:
On Mon, Jul 27, 2015 at 11:58 PM, Marcelo de Moraes Serpa <celoserpa@anonymised.com…> wrote:
bump
The heatmap one is definitely not, the algorithm currently implemented makes no sense when tiled (as it changes
the output taking into account everything in the requested bounding box, and if you slice it, you change
the input data).
If what you want to depict is not point density, but some representation of one of their attributes,
you might want to try the Barnes surface interpolation… while I have no experience with it,
by a quick look at the code, it seems it might tile correctly (at least, there seems to be some
The process has never been documented in GeoServer docs by its original author (Martin Davis),
If this is not what you’re looking for, rendering transformations are pluggable, so you can
either write your own, or have someone write it for you, see http://geoserver.org/support/
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jul 29, 2015 at 8:18 PM, Marcelo de Moraes Serpa <
Regarding generating the actual layer, do you think it'd be better to
vector data?
If you cannot get GeoServer to do what you want, and cannot develop your
own transformation either,
yes, that's a way.
It will become a problem to keep it up to date with your data, if the data
changes often. But if it does not change at all, you do it once by hand and
you're done.
Ing. Andrea Aime
@geowolf
Technical Lead
