[Geoserver-users] Serving up predefined geometric properties from GML namespace
I need GeoServer to serve up geometric properties in the GML namespace (e.g. gml:pointProperty, gml:polygonProperty) rather than the target namespace of the feature schema. Is this possible?
Arnau
Arnau Carrera ha scritto:
Hmmm... I'm wondering if this makes any sense to start with?
The property itself is defined in the application server, not in the
GML schema, so it should not be in that schema. The geometry values
(contents of the property) should be in the gml schema instead since
we are using elements defined directly in the GML schema.
Anyways, you can probably get what you want by doing an XSLT transformation against the outputs. Just, at the moment we have
no way to do so directly you'll have to proxy geoserver and
apply the transformation inside your custom built proxy.
There is also a patch floating around in this ml that allows
one to create a XSLT output format, you could apply it and build your
GeoServer.
Andrea Aime
OpenGeo - http://opengeo.org
Hi Andrea,
One can define a geometric property as follows: . This way one reuses GML built-in geometric properties. This practice is allowed in GML (see Section 8.2.3 in GML 3.1.1 and Section 5.2.7 in GML 2.1.2). I have an FME-generated GML schema that contains such properties.
Alex
Hmmm… I’m wondering if this makes any sense to start with?
no way to do so directly you’ll have to proxy geoserver and
GeoServer.
Andrea Aime
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Unfortunately the way GeoServer does its internal mapping to GML does not work this way. Instead it works like:
<element name="the_geom" type="gml:PointPropertyType"/>
The reason this is done is so that the name of the xml element matches the name of the geometric attribute of the dataset.
-Justin
Alex Milanovic wrote:
Hi Andrea,
One can define a geometric property as follows: <element ref="gml:pointProperty" minOccurs="0"/>. This way one reuses GML built-in geometric properties. This practice is allowed in GML (see Section 8.2.3 in GML 3.1.1 and Section 5.2.7 in GML 2.1.2). I have an FME-generated GML schema that contains such properties.
Alex
On Tue, Oct 28, 2008 at 12:42 PM, Andrea Aime <aaime@anonymised.com <mailto:aaime@anonymised.com>> wrote:
     > Hi,
     > I need GeoServer to serve up geometric properties in the GML
    namespace
     > (e.g. gml:pointProperty, gml:polygonProperty) rather than the target
     > namespace of the feature schema. Is this possible?
    GeoServer.
    Andrea Aime
    This SF.Net email is sponsored by the Moblin Your Move Developer's
    challenge
    great prizes
    the world
    <http://moblin-contest.org/redirect.php?banner_id=100&url=/&gt;
    <mailto:Geoserver-users@lists.sourceforge.net>
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Justin Deoliveira
