[Geoserver-users] Session timed out problem
I am new Geoserver user. I install Geoserver 2.3.2 and JDK 7u21 for 32bit on Window7.
I have added several layers on Geoserver.
Today I try to add some more layers, but when I click to Data Store button on Geoserver
website, one massage appear as:
Sorry, your session timed out…
It looks like you waited too long to make that last change.if this continues to happen, you should get in touch with your system administrator.
Go back to the home page and try again.
Someone told that it dues to permgen space in Java. But I check “startup.bat” script in C:\Program Files\GeoServer 2.3.2\bin
This script as follow:
call “C:\Program Files\Java\jre7\bin\java.exe” -DGEOSERVER_DATA_DIR=“C:\Program Files\GeoServer 2.3.2\data_dir” -Xmx1024m -XX:MaxPermSize=256m -DSTOP.PORT=8079 -DSTOP.KEY=geoserver -Djetty.port=8080 -Djetty.logs=“C:\Program Files\GeoServer 2.3.2\logs” -jar “C:\Program Files\GeoServer 2.3.2\start.jar”
In this command line, it’d already had option -Xmx1024m and -XX:MaxPermSize=256m
So that I guess my problem may caused by others reasons.
Could you help how to fix it?
Thank you all.
Hi Minh,
You’re the third person to report this in the last few weeks (I was the second).
What web-browser are you using? What steps does it take to replicate this?
With a bit more information maybe a pattern will emerge.
Jonathan
On 12 June 2013 04:35, Minh Nguyen Le <nlminh79@anonymised.com> wrote:
Thank you all.
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On Wed, Jun 12, 2013 at 2:02 PM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
Hi Minh,
  You're the third person to report this in the last few weeks (I was the
second).
Mind, sometimes this message pops up because the session was ruined by an
internal error in GeoServer,
if that's the case the error message should be available in the GeoServer
logs though
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
