[Geoserver-users] Setting InputTransparentColor from code
I'm new to GeoServer and I have a problem that I couldn't solved:
I'm creating a GeoTiff layer (creating CoverageStore + Coverage) via C# code
that wrapps REST APIs.
At the layer I also add the InputTransparentColor field with color value for
the GeoTiff to be transparent.
Everything seems to be created correctly. I see The layer and all its
fields, but when I look at the layer preview (and also in my UI client), the
GeoTiff image is not transparent.
IF I enter MANUALLY to the Edit Layer page of the GeoServer, and only press
the 'Save' button there, without changing anything, suddenly the image
becomes transparent.
I must create the layesrs automatically via code, and I can't enter manually
to the GeoServer to save.
What can I do via the code to resemble the manuall save?
How can I get the image to becomes transparent via the code / rest?
Revital.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Setting-InputTransparentColor-from-code-tp5252205.html
Generally speaking, anything that you can do manually in the GUI should
also be doable
with the REST API.
To discover how, check the coverage REST representation before manually
changing
the transparency, then change it via the GUI, go back and check again the
REST
representation: this should make it evident what you have to PUT in the
resource by code
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Thanks for you reply.
Maybe it's a silly question, but how can I check the coverage REST
representation?
Thanks a lot,
Revital.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Setting-InputTransparentColor-from-code-tp5252205p5252894.html
representation?
You did not check out user guide I assume?
http://docs.geoserver.org/latest/en/user/rest/index.html#rest
(or just googling "coverage rest geoserver", the answer is in the first two
results...)
Ing. Andrea Aime
@geowolf
Technical Lead
I actually read it, more than once :slight_smile:
But still couldn't fully understand how to do it (I'm new to REST not just
to the GeoServer).
But eventually I succeeded doing so, and you were right! I found the
difference.
The difference was that I entered the color from the code, as Hex number,
with no # before.
Apparently for the GeoServer to recognize the color for transparency it has
to be in the following pattern: #FFFFFF (makes sense since it is hex).
In the GUI of the GeoServer it looks the same, (without #) so I couldn't
understand the difference.
Thanks a lot!
Revital.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Setting-InputTransparentColor-from-code-tp5252205p5252906.html
