i'm going to use geoserver 2.8 for the first time as an servlet in my
existing jetty-server.
I need to specify an external data_directory and would like to to it with a
context file.
But i don't know the exact format and where to put this file. I tried the
directory "contexts" of jetty but it did not work for me.
GS Doc said "To specify the data directory using a servlet context
parameter, create the following <context-param> element in the
WEB-INF/web.xml file for the GeoServer application:"
but that is not clear for me.
Regards
walter
View this message in context: http://osgeo-org.1560.x6.nabble.com/setting-Servlet-context-parameter-in-jetty-tp5229293.html
