[Geoserver-users] Setting the Data Directory
Hi All,
I wanted to change the location of the data directory. First I changed the path on the web.xml file (even uncommented the section). When that didn't work I directly set the environment variable and that worked fine. I am using the binary version of geoserver (Jetty) on OSX.
Is the the start script is suppose to be looking toward the web.xml file for data directory information? Is so, shouldn't setting the variable in web.xml worked?
Alyssa.
Hi Alyssa,
Not sure if you have already found an answer or not but this is a known issue:
http://jira.codehaus.org/browse/GEOS-2618
I have managed to change the data directory by following instructions here:
http://www.astro.washington.edu/users/rowen/AquaEnvVar.html
With the caveat that I had to restart my computer to get the changes to take effect.
-Justin
alyssa wright wrote:
Hi All,
Alyssa.
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensign option that enables unlimited
royalty-free distribution of the report engine for externally facing server and web deployment.
http://p.sf.net/sfu/businessobjects
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
http://jira.codehaus.org/browse/GEOS-1883 was the last time I worked on it and documents the intended behavior, but I never tested it on OS X.
(and we've moved a bit away from GEOSERVER_DATA_ROOT so 3A and 3B are no longer applicable afaik)
-Arne
Justin Deoliveira wrote:
Hi Alyssa,
-Justin
Hi All,
Alyssa.
Arne Kepp
Expert service straight from the developers
