[Geoserver-users] Setting timestamp value using sql now() function on commit
Hello all,
I have a postgres db table that looks like this:
CREATE TABLE user_location
user_name character varying(50) NOT NULL,
user_bbox geometry NOT NULL,
user_enter_ts timestamp without time zone DEFAULT now(),
user_location_id serial NOT NULL,
CONSTRAINT user_location_id PRIMARY KEY (user_location_id)
Notice the user_enter_ts timestamp with the DEFAULT now() declaration.
What I am trying to accomplish is that upon feature commit(), the bbox and the user_name attributes are created the insert happens and the database takes care of the timestamp generation using the now function.
Unfortunately this is not happening.
If I run the insert in a sql pane: Insert into table (user_name,user_bbox) values (‘somename’,‘somebbox’)
I get a record with the users name, users_bbox and a postgres generated timestamp.
//This code below works well although I am relying on javascript to generate the timestamp(not what I want). The user_name, user_bbox and user_enter_ts all get inserted into the db
Here is the code for the attribute creation:
var d = new Date();
feature.attributes = {‘user_name’:USER,
‘user_enter_ts’:d.toISO8601String(6)
//I want to do this which would allow postgres to take care of the timestamp, however all that gets inserted into the db is user_name and user_bbox(no timestamp).
feature.attributes = {‘user_name’:USER };
//I also tried this(which doesnt work either):
‘user_enter_ts’:now())
Any ideas?
Thanks in advance.!
It would be helpful if we had the exact request being sent to geoserver in the cases where you are not specifying the date in Javascript. Any chance you have firebug available on your machine?
-Justin
g f wrote:
Hello all,
If I run the insert in a sql pane: Insert into table (user_name,user_bbox) values ('somename','somebbox')
var d = new Date();
        feature.attributes = {'user_name':USER,
                              'user_enter_ts':d.toISO8601String(6)
        feature.attributes = {'user_name':USER };
                              'user_enter_ts':now())
Any ideas?
Thanks in advance.!
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Thanks for the reply Justin
This is the POST which works(Using javascript to insert the timestamp)
<wfs:Transaction xmlns:wfs=“http://www.opengis.net/wfs” version=“1.0.0” service=“WFS”>wfs:Insert
<feature:user_location xmlns:feature=“https://www.djc2.org/schemas”>feature:user_bbox
<gml:MultiPolygon xmlns:gml=“http://www.opengis.net/gml”>gml:polygonMembergml:Polygongml:outerBoundaryIsgml:LinearRing
<gml:coordinates decimal=“.” cs=“,” ts=" ">-159.43359375,-17.05078125 42.36328125,-17.05078125 42.36328125
,50.44921875 -159.43359375,50.44921875 -159.43359375,-17.05078125</gml:coordinates></gml:LinearRing>
</gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon>
</feature:user_bbox>feature:user_nametest01</feature:user_name>
feature:user_enter_ts2009-03-18T15:32:47.024Z</feature:user_enter_ts></feature:user_location></wfs:Insert></wfs:Transaction>
This doesnt work as I dont generate the timestamp using javascript but rather am relying on postgres to populate it with the DEFAULT VALUE of now().
feature:user_bbox<gml:MultiPolygon xmlns:gml=“http://www.opengis.net/gml”>
gml:LinearRing<gml:coordinates decimal=“.” cs=“,” ts=" ">-273.1640625,-50.9765625 130.4296875,-50.9765625 130.4296875
,84.0234375 -273.1640625,84.0234375 -273.1640625,-50.9765625</gml:coordinates>
</gml:LinearRing>
</feature:user_bbox>feature:user_nametest01</feature:user_name></feature:user_location></wfs:Insert></wfs:Transaction>
Isnt there a way to pass the now string like so:
Thanks alot!
On Wed, Mar 18, 2009 at 10:17 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-Justin
g f wrote:
Hello all,
var d = new Date();
Any ideas?
Thanks in advance.!
Apps built with the Adobe(R) Flex(R) framework and Flex Builder™ are
easily build your RIAs with Flex Builder, the Eclipse™based development
Justin Deoliveira
So i looked into the problem and was able to reproduce the issue. The problem lies in the query being generated by the postgis datastore:
INSERT INTO "public"."user_location"
("user_name","user_bbox","user_enter_ts")
VALUES
('test01',setSRID('...'::geometry,4326),null)
As you can see null is explicitly being inserted, which is bogus.
Can you open a bug report on jira.codehaus.org? Thanks.
-Justin
<wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs&quot; version="1.0.0" service="WFS"><wfs:Insert>
<feature:user_location xmlns:feature="https://www.djc2.org/schemas&quot;&gt;&lt;feature:user\_bbox&gt;
<gml:MultiPolygon xmlns:gml="http://www.opengis.net/gml&quot;&gt;&lt;gml:polygonMember&gt;&lt;gml:Polygon&gt;&lt;gml:outerBoundaryIs&gt;&lt;gml:LinearRing&gt;
<gml:coordinates decimal="." cs="," ts=" ">-159.43359375,-17.05078125 42.36328125,-17.05078125 42.36328125
</feature:user_bbox><feature:user_name>test01</feature:user_name>
<feature:user_enter_ts>2009-03-18T15:32:47.024Z</feature:user_enter_ts></feature:user_location></wfs:Insert></wfs:Transaction>
<feature:user_bbox><gml:MultiPolygon xmlns:gml="http://www.opengis.net/gml&quot;&gt;
<gml:polygonMember><gml:Polygon><gml:outerBoundaryIs>
<gml:LinearRing><gml:coordinates decimal="." cs="," ts=" ">-273.1640625,-50.9765625 130.4296875,-50.9765625 130.4296875
</gml:LinearRing>
</feature:user_bbox><feature:user_name>test01</feature:user_name></feature:user_location></wfs:Insert></wfs:Transaction>
Thanks alot!
On Wed, Mar 18, 2009 at 10:17 AM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    -Justin
    g f wrote:
        Hello all,
        declaration.
        var d = new Date();
        Any ideas?
        Thanks in advance.!
        Builder(TM) are
        Quickly and
        development
        <mailto:Geoserver-users@lists.sourceforge.net>
    -- Justin Deoliveira
Justin Deoliveira
