Hi List,
I’m trying to set up new LDAP authentication provider (there’s none yet).
I enter the Server URL:
ldap://servername.wcc-corp.ad
And the username/password.
At this point if I click “Test Connection” I get:
No user dn pattern specified
So I enter a User Lookup Pattern. But no matter what I enter in the User Lookup pattern, Clicking test, Geoserver always returns:
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
I’ve tried:
users={0}
{0}
dn=jmou1,ou=datacentre-cx,ou =cg,ou=users,ou=wcc,dc=wcc-corp,dc=ad
cn=jmou1,ou=datacentre-cx,ou=cg,ou=users,ou=wcc,dc=wcc-corp,dc=ad
cn=users,ou=wcc,dc=wcc-corp,dc=ad
ou=groups,ou=wcc,dc=wcc-corp,dc=ad
random letters
In fact, the only thing that doesn’t result in that error is putting only spaces in there (it asks for the user dn pattern instead).
At this point, given the error remains consistent, is this a bug in GeoServer (2.3.0)? Otherwise, what do I put into the User Lookup pattern?
The console error starts:
20 Mar 16:07:36 WARN [org.geoserver.web.security] - String index out of range: -1
at java.lang.String.substring(Unknown Source)
at org.geoserver.web.security.ldap.LDAPAuthProviderPanel$TestLDAPConnectionPanel$1.doTest(LDAPAuthProviderPanel.java:171)
at org.geoserver.web.security.ldap.LDAPAuthProviderPanel$TestLDAPConnectionPanel$1.onSubmit(LDAPAuthProviderPanel.java:147)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
