List,
I’m currently look to move from my testing environment to a live one and was wondering if anyone could provide any advice or tips.
At present I’m using:
· VMware Virtual Machine
· 2 Physical Processors (Intel® Xeon® CPU E5-2680 0 @ 2.70GHz)
· 4GB RAM
· Windows Server 2008 R2 Standard Edition x64
· Geoserver 2.3.0 running as a service installed via the Windows Installer through Jetty
· Oracle JRE 6 (32-bit)
I’m planning on having my VM replicated and then installing everything from scratch on it (so up-to-date Geoserver, etc.). however I have a few questions that I’ve found conflicting or limited advice on the internet about:
As I don’t have an existing servlet container application (e.g. Tomcat), I’m presuming my options are either using the Windows Installer or the Windows Binary; is one preferred, what are the pros/cons?
Should I be using the JRE or JDK (or indeed Server JRE); I know that only JRE is required but I’ve seen some people advised in the past to use the JDK (I think it was using the latest version)?
Which version of JRE/JDK should be used, I’ve been recommended to use JRE6 in the past but should I now be using JRE7; are there any compatibility/security issues with either?
Also I note that if you use the Windows 64-bit JRE/JDK you cannot run Geoserver as a Service, what are the disadvantages of this, any recommendations?
Again with the Windows 64-bit JRE/JDK; there doesn’t seem to be an option to install native JAI and JAI Image I/O extensions, would it be better to use the 64-bit JRE with the pure Java versions or use the 32-bit JRE with the native extensions?
How have people found the best way to upgrade Geoserver to the new point releases? Is the only way to take everything down, uninstall completely then reinstall Geoserver (+ extensions, etc.) every time? Any tips on limiting downtime?
Thanks for your time and apologies for the number of questions.
Rob
<br>DISCLAIMER: The information contained in this communication/message from Robert.Langford@anonymised.com..5490... sent on Wed Jun 26 16:15:52 2013 is confidential and may be legally privileged. It is intended solely for the addressee(s) geoserver-users@anonymised.comists.sourceforge.net<br><br>Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.<br>As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.<br>Please immediately contact the sender, Robert.Langford@anonymised.com if you have received this message in error.<br><br>For the full disclaimer please access http://www.salford.gov.uk/e-mail. Thank you.<br> |
