[Geoserver-users] Shape connection path
How can I change the connection path of the shapefile location in the source configuration. Ans I mean not in the the front-end application page of geoserver but in the sourcefiles with notepad++. The reason is the amount of sources (over 1000).
Thanks
Met vriendelijke groet,
Erik-Jan Martens
Geo-informatiebeheerder
GRSK- SSC de Kempen
Tel.: 0497551489
Email: e.martens@anonymised.com
Ciao Erik,
assuming you know what you are doing, I believe you need to check the content of a store XML config file. You’ll recognize the element to use as a pivot.
Simone.
Il 28/Mag/2015 15:38, “Erik Jan Martens” <E.Martens@anonymised.com> ha scritto:
Thanks
Erik-Jan Martens
GRSK- SSC de Kempen
Tel.: 0497551489
Email: e.martens@anonymised.com88…
Op dit bericht is een disclaimer van toepassing. De volledige tekst vindt u op:
http://www.kempengemeenten.nl/maildisclaimer
Geoserver-users mailing list
