Hi
I have a shapefile for the world that I am using with an SLD to fill the polygons, and a background color.
The shapefile came from freegis and is 28 meg in size. However, it is pretty slow to render – my dev box is 3gig processor with 3 gig memory, and this is the war release on tomcat – should it really take 10 secs to render the maps at 1024 x 768 into openlayers?
Should I be using tiled TIFFs for the background?
I am trying to get oscache working, but it seems to always return miss on cache checking, but I think that 10 secs to render the map is probably not correct anyway.
Thanks
Tim
Tim Robertson ha scritto:
Hi
The problem is, afaik, that the map is quite detailed, but you don't need all that detail when rendering at 1024x768.
Can you post the link to the file? I can see if there's anything
wrong with Geoserver rendering it.
Anyways, I would suggest you to go multiresolution if you want good
performance at all levels:
* load the data into postgis
* create new geometric columns for the simplified geometries
* use the postgis Simplify(geometry, tolerance) command, along with
an insert, to create the simplified geometries
* use SLD to decide which column to render depending on the zoom
level.
As an alternative, if you're using Geoserver 1.5.0, ask getMap to
produce a big Geotiff image (format=image/geotiff if I remember properly) and then use gdaladdo to add overviews, then reuse it
in Geoserver as a raster layer (the catch here is that Geoserver
will render the full image in memory, so you'll risk an OOM unless
you did start Geoserver with a high -Xmx value, such as -Xmx1024m).
Hope this helps
You should probably use TileCache, if you can install python. That's our currently recommended way to do caching.
http://docs.codehaus.org/display/GEOSDOC/TileCache+Tutorial
Chris
Tim Robertson wrote:
Hi
Thanks
Tim
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Hi Andrea,
Thank you very much for this - followed it all except for the "use an SLD
to determine which column to render"... I know you can set the min/max
scale denominators, but I dont know how to pick a column based on this -
could you please elaborate?
Many thanks again
Tim
Hi
level.
Hope this helps
Hi Andrea,
With regard to selecting the column to render...
<PolygonSymbolizer>
<GeometryProperty><ogc:PropertyName>highlevel</ogc:PropertyName></GeometryProperty>
<Fill>
<CssParameter name="fill">#DDDDDD</CssParameter>
<CssParameter name="fill-opacity">1</CssParameter>
</Fill>
</PolygonSymbolizer>
Is this correct? I am not convinced that it is working, as I have both
"geom" and "highlevel" (daft names I know but this is just prototyping at
the moment) columns in the DB - however, when I try and use
ogc:PropertyName's that dont exist in the SLD it still renders fine. I am
not convinced it is picking up the "low res" geometry column, with that
SLD snippet above.
Incidentally, loading the shapefile into postgis alone sped things up
massively, but I'd still like to tile/layer it.
Thanks
Tim
Hi
level.
Hope this helps
trobertson@anonymised.com ha scritto:
Hi Andrea,
<PolygonSymbolizer>
<Fill>
</Fill>
Is this correct?
Yes, it is.
SLD snippet above.
Funny... I just tried on my PC, and could not reproduce, it's throwing an error complaining about a non existent attribute... wait...
there's one thing you may not know. Geoserver parses the style on first usage, and it keeps the parsed version in memory. So, if you alter the
sld directly on disk, Geoserver wont' notice and will keep using the
old pre-parsed sld.
If you update the file directly, you'll have to restart GeoServer as well. It's a pity, I know.
Hum... interesting. Usually postgis is faster when zoomed in, that is,
when spatial indexes can make the difference, but slower when displaying
the full map. In your case it's always faster (even without the generalized geometries)? What shapefile datastore are you using, the standard one, or the indexed one?
Hi Andrea,
Thanks again for reply.
SLD snippet above.
- Funny... I just tried on my PC, and could not reproduce, it's throwing
- an error complaining about a non existent attribute... wait...
- there's one thing you may not know. Geoserver parses the style on first
- usage, and it keeps the parsed version in memory. So, if you alter the
- sld directly on disk, Geoserver wont' notice and will keep using the
- old pre-parsed sld.
- If you update the file directly, you'll have to restart GeoServer as
- well. It's a pity, I know.
I do restart tomcat to pick it up. I'll work out how to log SQL on
postgres, and see exactly what is being issued to see if there is an issue.
Perhaps it is the rendering itself as I have no JAI as I am on Mac?
- Hum... interesting. Usually postgis is faster when zoomed in, that is,
- when spatial indexes can make the difference, but slower when displaying
- the full map. In your case it's always faster (even without the
- generalized geometries)? What shapefile datastore are you using, the
- standard one, or the indexed one?
It was the non indexed one, so I guess that would explain it.
