Hi
I’m using the latest nightly build and I have some errors thrown when making a wfs-request with shape-zip outputformat (against a postgis view, the topp:states works fine):
08 Apr 11:32:16 WARN [data.shapefile] - FieldName orientation is longer than 10 characters, truncating to orientatio
08 Apr 11:32:16 ERROR [data.shapefile] - The following locker still has a lock? read on file:/usr/local/apache-tomcat-5.5.25/temp/wfsshptemp0.3726904232079601/pdfprintlog_point_v.shp by org.geotools.data.shapefile.shp.ShapefileReader
it was created with the following stack trace
org.geotools.data.shapefile.ShpFilesLocker$Trace: Locking file:/usr/local/apache-tomcat-5.5.25/temp/wfsshptemp0.3726904232079601/pdfprintlog_point_v.shp for read by org.geotools.data.shapefile.shp.ShapefileReader in thread http-8080-Processor42
at org.geotools.data.shapefile.ShpFilesLocker.setTraceException(ShpFilesLocker.java:54)
at org.geotools.data.shapefile.ShpFilesLocker.(ShpFilesLocker.java:33)
at org.geotools.data.shapefile.ShpFiles.acquireRead(ShpFiles.java:365)
at org.geotools.data.shapefile.ShpFiles.getReadChannel(ShpFiles.java:813)
at org.geotools.data.shapefile.shp.ShapefileReader.(ShapefileReader.java:142)
at org.geotools.data.shapefile.ShapefileDataStore.openShapeReader(ShapefileDataStore.java:425)
at org.geotools.data.shapefile.ShapefileDataStore.getAttributesReader(ShapefileDataStore.java:411)
at org.geotools.data.shapefile.ShapefileDataStore.createFeatureWriter(ShapefileDataStore.java:572)
at org.geotools.data.AbstractDataStore.getFeatureWriter(AbstractDataStore.java:486)
at org.geotools.data.AbstractDataStore.getFeatureWriter(AbstractDataStore.java:520)
at org.geotools.data.AbstractDataStore.getFeatureWriterAppend(AbstractDataStore.java:529)
at org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.java:254)
at org.geoserver.wfs.response.ShapeZipOutputFormat.writeCollectionToShapefile(ShapeZipOutputFormat.java:199)
at org.geoserver.wfs.response.ShapeZipOutputFormat.write(ShapeZipOutputFormat.java:157)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:137)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:711)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:874)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:619)
08 Apr 11:32:16 ERROR [data.shapefile] - The following locker still has a lock? read on file:/usr/local/apache-tomcat-5.5.25/temp/wfsshptemp0.3726904232079601/pdfprintlog_point_v.dbf by org.geotools.data.shapefile.dbf.DbaseFileReader
org.geotools.data.shapefile.ShpFilesLocker$Trace: Locking file:/usr/local/apache-tomcat-5.5.25/temp/wfsshptemp0.3726904232079601/pdfprintlog_point_v.dbf for read by org.geotools.data.shapefile.dbf.DbaseFileReader in thread http-8080-Processor42
at org.geotools.data.shapefile.dbf.DbaseFileReader.(DbaseFileReader.java:130)
at org.geotools.data.shapefile.ShapefileDataStore.openDbfReader(ShapefileDataStore.java:450)
08 Apr 11:32:16 ERROR [geoserver.ows] -
java.lang.NullPointerException
at org.geotools.data.shapefile.ShapefileFeatureWriter.write(ShapefileFeatureWriter.java:353)
at org.geotools.data.shapefile.ShapefileFeatureWriter.close(ShapefileFeatureWriter.java:218)
at org.geotools.data.InProcessLockingManager$1.close(InProcessLockingManager.java:348)
at org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.java:276)
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
Verified, this is a regression. Perhaps with some recent changes to Shapefile? Andrea should be able to better comment.
Ziegler Stefan wrote:
Hi
I'm using the latest nightly build and I have some errors thrown when making a wfs-request with shape-zip outputformat (against a postgis view, the topp:states works fine):
at org.geotools.data.shapefile.ShpFilesLocker.<init>(ShpFilesLocker.java:33)
at org.geotools.data.shapefile.shp.ShapefileReader.<init>(ShapefileReader.java:142)
at org.geotools.data.shapefile.dbf.DbaseFileReader.<init>(DbaseFileReader.java:130)
regards
Stefan
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Rötistrasse 4
4501 Solothurn
http://www.so.ch
This SF.net email is sponsored by:
High Quality Requirements in a Collaborative Environment.
Download a free trial of Rational Requirements Composer Now!
http://p.sf.net/sfu/www-ibm-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Apparently not. I can generate SHAPE-ZIP outputs from a 1.7.x
+ 2.5.x checkout without any issue.
I'll first have to restore the build of gt2 2.5.x on Unix (on XP
is fine, that's why I did not notice) and then see if it's another
(or the same) OS specific thing.
Andrea Aime
Forgot to mention that I can do so out of a postgis table.
Andrea Aime
