[Geoserver-users] Shapefile and Blank "Native SRS" field?
I uploaded a shapefile as a store, and created a layer, but for some reason,
the “Native SRS” field comes up blank, and is uneditable.
I can edit and save the “Declared SRS” field, and force the declared SRS
and view the layer in Open Layers, where it will display; however its
projected approximately 300 miles away from the correct location.
The native projection is known to me, how can I edit and save the Native SRS
field in Geoserver? The shapefile seems to work fine in Grass GIS.
Thanks!
are you sure you filled in the correct EPSG code in the declared SRS box? check prj2epsg.org to see what it should be.
Ian
Thanks!
Minimize network downtime and maximize team effectiveness.
Reduce network management and security costs.Learn how to hire
the most talented Cisco Certified professionals. Visit the
Employer Resources Portal
http://www.cisco.com/web/learning/employer_resources/index.html
Geoserver-users mailing list
Ian Turton
