[Geoserver-users] Shapefile output and ogc filter
I'm trying to obtain a shapefile using an ogc filter with a bbox inside. My
http get request is:
http://localhost:8080/geoserver/wfs?request=getfeature&
service=wfs&version=1.0.0&
typename=simo:bndpolamoz&
outputformat=SHAPE-ZIP&
filter=<ogc:Filter
xmlns:ogc="http://ogc.org"xmlns:gml="http://www.opengis.net/gml&quot;&gt;
<ogc:BBOX>
<ogc:PropertyName>the_geom</ogc:PropertyName>
<gml:Box srsName="4326">
<gml:coordinates>31.1,-20.8 38.8,-15.3</gml:coordinates>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
But it returns the following error:
<ServiceExceptionReport version="1.2.0"
xsi:schemaLocation="http://www.opengis.net/ogc
http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd&quot;&gt;
<ServiceException
locator="org.vfny.geoserver.util.requests.readers.XmlRequestReader">
      org.xml.sax.SAXParseException: Element type "ogc:Filter" must be
followed by either attribute specifications, ">" or "/>".
Element type "ogc:Filter" must be followed by either attribute
</ServiceException>
</ServiceExceptionReport>
Can anyone help me?
Thanks in advance.
Simone
View this message in context: http://www.nabble.com/Shapefile-output-and-ogc-filter-tp19288721p19288721.html
<ogc:Filter
I think you need some whitespace between 'xmlns:ogc="http://ogc.org"' and 'xmlns:gml="http://www.opengis.net/gml&quot;&#39;\.
A. Soroka / Digital Scholarship Services R & D
the University of Virginia Library
On Sep 3, 2008, at 9:01 AM, Simo D wrote:
filter=<ogc:Filter
<ogc:BBOX>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
<ServiceException
</ServiceException>
Can anyone help me?
Thanks in advance.
Simone
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Yes, thank you, I've modified the query also in the srsName with:
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4326&quot;&gt;
but now the error is:
<ServiceException
      org.xml.sax.SAXParseException: XML document structures must start and
end within the same entity.
XML document structures must start and end within the same entity.
</ServiceException>
All the tags seems to be opened and closed in the proper way.
Thanks again.
Simone
ajs6f@anonymised.com wrote:
<ogc:Filter
inside. My
filter=<ogc:Filter
<ogc:BBOX>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
<ServiceException
</ServiceException>
Can anyone help me?
Thanks in advance.
Simone
challenge
great prizes
the world
challenge
prizes
world
View this message in context: http://www.nabble.com/Shapefile-output-and-ogc-filter-tp19288721p19289354.html
Hi Simone,
How are you making the request? In a web browser... some custom code making the http request? etc... my guess is that the filter is not being URL encoded properly. I could be wrong but I copied your filter into the browser and executed a request and it works ok... More info should help.
-Justin
<ServiceException
</ServiceException>
Thanks again.
Simone
<ogc:Filter
filter=<ogc:Filter
<ogc:BBOX>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
<ServiceException
</ServiceException>
Can anyone help me?
Thanks in advance.
Simone
challenge
prizes
world
Justin Deoliveira
Software Engineer, OpenGeo
http://opengeo.org
Yes I make the request in the browser directly because is a first try and
this is the request:
filter=<ogc:Filter xmlns:ogc="http://ogc.org"
<ogc:BBOX>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
The request without the filter works properly and I'm sure that the bbox is
correct.
thanks
Justin Deoliveira-6 wrote:
Hi Simone,
-Justin
<ServiceException
and
</ServiceException>
Thanks again.
Simone
<ogc:Filter
inside. My
filter=<ogc:Filter
<ogc:BBOX>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
<ServiceException
</ServiceException>
Can anyone help me?
Thanks in advance.
Simone
challenge
great prizes
the world
challenge
prizes
world
Justin Deoliveira
http://opengeo.org
challenge
prizes
world
View this message in context: http://www.nabble.com/Shapefile-output-and-ogc-filter-tp19288721p19292569.html
You already tried to use the CQL? It sees the example:
http://geoserver.org/display/GEOSDOC/WFS+vendor+parameters
Best Regards,
Fernando Quadro
http://www.fernandoquadro.com.br
fsquadro@…95…
Date: Wed, 3 Sep 2008 09:13:27 -0700
Subject: Re: [Geoserver-users] Shapefile output and ogc filter
filter=<ogc:Filter xmlns:ogc=“http://ogc.org
xmlns:gml=“http://www.opengis.net/gml”>
ogc:BBOX
ogc:PropertyNamethe_geom</ogc:PropertyName>
<gml:Box srsName=“http://www.opengis.net/gml/srs/epsg.xml#4326”>
gml:coordinates31.1,-20.8 38.8,-15.3</gml:coordinates>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
The request without the filter works properly and I’m sure that the bbox is
correct.
thanks
Hi Simone,
How are you making the request? In a web browser… some custom code
making the http request? etc… my guess is that the filter is not being
browser and executed a request and it works ok… More info should help.
-Justin
Simo D wrote:
Yes, thank you, I’ve modified the query also in the srsName with:
and
Thanks again.
Simone
ajs6f@…1704… wrote:
<ogc:Filter
xmlns:ogc="http://ogc.org"xmlns:gml=“http://www.opengis.net/gml”>
I think you need some whitespace between ‘xmlns:ogc=“http://ogc.org”’
and ‘xmlns:gml=“http://www.opengis.net/gml”’.
I’m trying to obtain a shapefile using an ogc filter with a bbox
inside. My
filter=<ogc:Filter
ogc:BBOX
<gml:Box srsName=“4326”>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
org.xml.sax.SAXParseException: Element type “ogc:Filter” must be
followed by either attribute specifications, “>” or “/>”.
Element type “ogc:Filter” must be followed by either attribute
Can anyone help me?
Thanks in advance.
Simone
This SF.Net email is sponsored by the Moblin Your Move Developer’s
challenge
great prizes
the world
challenge
prizes
world
Justin Deoliveira
http://opengeo.org
challenge
prizes
world
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Notícias direto do New York Times, gols do Lance, videocassetadas e muitos outros vídeos no MSN Videos! Confira já!
Yes, it work in this way.
Thank you!
Simone
Fernando Quadro wrote:
Hi, You already tried to use the CQL? It sees the example:
http://geoserver.org/display/GEOSDOC/WFS+vendor+parameters Best
Regards,Fernando Quadro
http://www.fernandoquadro.com.brfsquadro@anonymised.com
Date: Wed, 3 Sep 2008 09:13:27 -0700> From: simone.dalmasso@anonymised.com>
To: geoserver-users@lists.sourceforge.net> Subject: Re: [Geoserver-users]
Shapefile output and ogc filter> > > Yes I make the request in the
browser directly because is a first try and> this is the request:> >
http://localhost:8080/geoserver/wfs?request=getfeature&&gt;
service=wfs&version=1.0.0&> typename=simo:bndpolamoz&>
outputformat=SHAPE-ZIP&> filter=<ogc:Filter xmlns:ogc="http://ogc.org">
xmlns:gml="http://www.opengis.net/gml&quot;&gt;&gt; <ogc:BBOX>>
<ogc:PropertyName>the_geom</ogc:PropertyName>> <gml:Box
srsName="http://www.opengis.net/gml/srs/epsg.xml#4326&quot;&gt;&gt;
<gml:coordinates>31.1,-20.8 38.8,-15.3</gml:coordinates>> </gml:Box>>
</ogc:BBOX>> </ogc:Filter>> > The request without the filter works
properly and I'm sure that the bbox is> correct.> > thanks> > Justin
Deoliveira-6 wrote:> > > > Hi Simone,> > > > How are you making the
request? In a web browser... some custom code > > making the http
request? etc... my guess is that the filter is not being > > URL encoded
properly. I could be wrong but I copied your filter into the > > browser
and executed a request and it works ok... More info should help.> > > >
-Justin> > > > Simo D wrote:> >> Yes, thank you, I've modified the query
also in the srsName with:> >> <gml:Box
srsName="http://www.opengis.net/gml/srs/epsg.xml#4326&quot;&gt;&gt; >> > >> but now
the error is:> >> <ServiceExceptionReport version="1.2.0"> >>
xsi:schemaLocation="http://www.opengis.net/ogc&gt; >>
http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd&quot;&gt;&gt; >> −> >>
<ServiceException> >>
locator="org.vfny.geoserver.util.requests.readers.XmlRequestReader">> >>
> >> org.xml.sax.SAXParseException: XML document structures must start>
>> and> >> end within the same entity.> >> XML document structures must
start and end within the same entity.> >> </ServiceException>> >>
</ServiceExceptionReport>> >> > >> All the tags seems to be opened and
closed in the proper way.> >> Thanks again.> >> > >> Simone> >> > >> > >>
ajs6f@anonymised.com wrote:> >>>> <ogc:Filter> >>>>
xmlns:ogc="http://ogc.org"xmlns:gml="http://www.opengis.net/gml&quot;&gt;&gt; >>> I
think you need some whitespace between 'xmlns:ogc="http://ogc.org"' > >>>
and 'xmlns:gml="http://www.opengis.net/gml&quot;&#39;\.&gt; >>>> >>> ---> >>> A.
Soroka / Digital Scholarship Services R & D> >>> the University of
Virginia Library> >>>> >>>> >>>> >>> On Sep 3, 2008, at 9:01 AM, Simo D
wrote:> >>>> >>>> Hi all,> >>>> I'm trying to obtain a shapefile using an
ogc filter with a bbox > >>>> inside. My> >>>> http get request is:> >>>>
http://localhost:8080/geoserver/wfs?request=getfeature&&gt; >>>>
service=wfs&version=1.0.0&> >>>> typename=simo:bndpolamoz&> >>>>
outputformat=SHAPE-ZIP&> >>>> filter=<ogc:Filter> >>>>
xmlns:ogc="http://ogc.org"xmlns:gml="http://www.opengis.net/gml&quot;&gt;&gt; >>>>
<ogc:BBOX>> >>>> <ogc:PropertyName>the_geom</ogc:PropertyName>> >>>>
<gml:Box srsName="4326">> >>>> <gml:coordinates>31.1,-20.8
38.8,-15.3</gml:coordinates>> >>>> </gml:Box>> >>>> </ogc:BBOX>> >>>>
</ogc:Filter>> >>>>> >>>> But it returns the following error:> >>>>
<ServiceExceptionReport version="1.2.0"> >>>>
xsi:schemaLocation="http://www.opengis.net/ogc&gt; >>>>
http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd&quot;&gt;&gt; >>>> −> >>>>
<ServiceException> >>>>
be> >>>> followed by either attribute specifications, ">" or "/>".> >>>>
Element type "ogc:Filter" must be followed by either attribute> >>>>
specifications, ">" or "/>".> >>>> </ServiceException>> >>>>
</ServiceExceptionReport>> >>>>> >>>> Can anyone help me?> >>>> Thanks in
advance.> >>>> Simone> >>>> -- > >>>> View this message in context:> >>>>
http://www.nabble.com/Shapefile-output-and-ogc-filter-tp19288721p19288721.html&gt;
>>>> Sent from the GeoServer - User mailing list archive at Nabble.com.>
>>>> This SF.Net email is sponsored by the Moblin Your Move Developer's >
>>>> challenge> >>>> Build the coolest Linux based applications with
Moblin SDK & win > >>>> great prizes> >>>> Grand prize is a trip for two
to an Open Source event anywhere in > >>>> the world> >>>>
http://moblin-contest.org/redirect.php?banner_id=100&url=/&gt; >>>>
_______________________________________________> >>>> Geoserver-users
mailing list> >>>> Geoserver-users@lists.sourceforge.net> >>>>
https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt; >>>> >>>
>>> This SF.Net email is sponsored by the Moblin Your Move Developer's>
>>> challenge> >>> Build the coolest Linux based applications with Moblin
SDK & win great> >>> prizes> >>> Grand prize is a trip for two to an Open
Source event anywhere in the> >>> world> >>>
_______________________________________________> >>> Geoserver-users
mailing list> >>> Geoserver-users@lists.sourceforge.net> >>>
https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt; >>>> >>>>
>> > > > > > > -- > > Justin Deoliveira> > Software Engineer, OpenGeo> >
http://opengeo.org> > > >
> This SF.Net email is sponsored by the Moblin Your Move Developer's> >
challenge> > Build the coolest Linux based applications with Moblin SDK &
win great> > prizes> > Grand prize is a trip for two to an Open Source
event anywhere in the> > world> >
_______________________________________________> > Geoserver-users
mailing list> > Geoserver-users@lists.sourceforge.net> >
https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt; > > > > >
-- > View this message in context:
http://www.nabble.com/Shapefile-output-and-ogc-filter-tp19288721p19292569.html&gt;
Sent from the GeoServer - User mailing list archive at Nabble.com.> > >
challenge> Build the coolest Linux based applications with Moblin SDK &
win great prizes> Grand prize is a trip for two to an Open Source event
anywhere in the world>
_______________________________________________> Geoserver-users mailing
list> Geoserver-users@lists.sourceforge.net>
_________________________________________________________________
Confira vídeos com notícias do NY Times, gols direto do Lance,
videocassetadas e muito mais no MSN Video!
http://video.msn.com/?mkt=pt-br
challenge
prizes
world
View this message in context: http://www.nabble.com/Shapefile-output-and-ogc-filter-tp19288721p19305975.html
<ogc:BBOX>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
I can confirm it's a url encoding issue. I usually use firefox
and it url encodes automatically the filters for me, but in this
case there is somethign that's throwing it off.
I used this page to url-encode the filter
http://www.albionresearch.com/misc/urlencode.php
and the result works.
Changed the bbox so that it covers USA and modified the layer
name so that I can hit geo.openplans.org. Modified filter:
<ogc:Filter xmlns:ogc="http://ogc.org" xmlns:gml="http://www.opengis.net/gml&quot;&gt;
  <ogc:BBOX>
      <gml:coordinates>-90,20 -60,40</gml:coordinates>
    </gml:Box>
  </ogc:BBOX>
</ogc:Filter>
The resulting request is:
http://geo.openplans.org:8080/geoserver/wfs?request=getfeature&service=wfs&version=1.0.0&typename=topp:states&outputformat=SHAPE-ZIP&filter=<ogc%3AFilter+xmlns%3Aogc%3D"http%3A%2F%2Fwww.opengis.net%2Fogc"+xmlns%3Agml%3D"http%3A%2F%2Fwww.opengis.net%2Fgml"><ogc%3ABBOX><ogc%3APropertyName>the_geom<%2Fogc%3APropertyName><gml%3ABox+srsName%3D"http%3A%2F%2Fwww.opengis.net%2Fgml%2Fsrs%2Fepsg.xml%234326"><gml%3Acoordinates>31.1%2C-20.8+38.8%2C-15.3<%2Fgml%3Acoordinates><%2Fgml%3ABox><%2Fogc%3ABBOX><%2Fogc%3AFilter>
Hope this helps
