Something I discovered while trying to extract a shapefile from GeoServer 1.5:
produces a shapefile with a .prj with these contents:
PROJCS[“NAD_1983_StatePlane_Massachusetts_Mainland_FIPS_2001”,
GEOGCS[“GCS_North_American_1983”,
DATUM[“D_North_American_1983”,
SPHEROID[“GRS_1980”, 6378137.0, 298.257222101]],
PRIMEM[“Greenwich”, 0.0],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Lon”, EAST],
AXIS[“Lat”, NORTH]],
PROJECTION[“Lambert_Conformal_Conic”],
PARAMETER[“central_meridian”, -71.5],
PARAMETER[“latitude_of_origin”, 41.0],
PARAMETER[“standard_parallel_1”, 41.71666666666667],
PARAMETER[“scale_factor”, 1.0],
PARAMETER[“false_easting”, 200000.0],
PARAMETER[“false_northing”, 750000.0],
PARAMETER[“standard_parallel_2”, 42.68333333333334],
UNIT[“m”, 1.0],
AXIS[“x”, EAST],
AXIS[“y”, NORTH]]
A prj of the same layer exported from SDE to a shapefile has these contents:
PROJCS[“NAD_1983_StatePlane_Massachusetts_Mainland_FIPS_2001”,GEOGCS[“GCS_North_American_1983”,DATUM[“D_North_American_1983”,SPHEROID[“GRS_1980”,6378137.0,298.257222101]],PRIMEM[“Greenwich”,0.0],UNIT[“Degree”,0.0174532925199433]],PROJECTION[“Lambert_Conformal_Conic”],PARAMETER[“False_Easting”,200000.0],PARAMETER[“False_Northing”,750000.0],PARAMETER[“Central_Meridian”,-71.5],PARAMETER[“Standard_Parallel_1”,41.71666666666667],PARAMETER[“Standard_Parallel_2”,42.68333333333333],PARAMETER[“Latitude_Of_Origin”,41.0],UNIT[“Meter”,1.0]]
The shapefile extracted from GeoServer when added to ArcMap generates a warning about the projection and the coordinate system is undefined when the properties of the layer are looked at. (It does draw though). I fiddled with the .prj of the version extracted from GeoServer and kept loading it into ArcMap and found that changing the slight differences (“m” versus “meter” or the order of things) didn’t make the .prj recognizable to ArcMap. What mattered was getting rid of all the hard returns.
So the version from GeoServer then becomes:
PROJCS[“NAD_1983_StatePlane_Massachusetts_Mainland_FIPS_2001”,GEOGCS[“GCS_North_American_1983”,DATUM[“D_North_American_1983”,SPHEROID[“GRS_1980”, 6378137.0, 298.257222101]],PRIMEM[“Greenwich”, 0.0],UNIT[“degree”, 0.017453292519943295],AXIS[“Lon”, EAST],AXIS[“Lat”, NORTH]],PROJECTION[“Lambert_Conformal_Conic”],PARAMETER[“central_meridian”, -71.5],PARAMETER[“latitude_of_origin”, 41.0],PARAMETER[“standard_parallel_1”, 41.71666666666667],PARAMETER[“scale_factor”, 1.0],PARAMETER[“false_easting”, 200000.0],PARAMETER[“false_northing”, 750000.0],PARAMETER[“standard_parallel_2”, 42.68333333333334],UNIT[“m”, 1.0],AXIS[“x”, EAST],AXIS[“y”, NORTH]]
which is not identical to the one from SDE, but ArcMap can read it. The GeoServer shapefile draws over the SDE layer.
This document from ESRI which describes how to create a .prj http://support.esri.com/index.cfm?fa=knowledgebase.techarticles.articleShow&d=14056 says that the string should be continuous.
Also, the “m” in UNIT should I think be “meter”, because when it is “m”, the measure tool in ArcMap says “unknown units” (it says “meters” when the .prj has “meter”)
