Correct. One layer would be the temperature field, the next the air pressure field, etc.
From: <andrea.aime@anonymised.com<mailto:andrea.aime@anonymised.com>> on behalf of Andrea Aime <andrea.aime@anonymised.com<mailto:andrea.aime@anonymised.com>>
Date: Monday, November 9, 2015 at 2:52 PM
To: David Marks <david.marks@anonymised.com<mailto:david.marks@anonymised.com>>
Cc: "geoserver-users@lists.sourceforge.net<mailto:geoserver-users@anonymised.comrceforge.net>" <geoserver-users@lists.sourceforge.net<mailto:geoserver-users@lists.sourceforge.net>>
Subject: Re: [Geoserver-users] Shapefile Publishing
On Mon, Nov 9, 2015 at 6:10 PM, Marks, David <David.Marks@anonymised.com<mailto:David.Marks@anonymised.com>> wrote:
Hello Geoserver-users,
I am currently producing shapefiles to publish into Geoserver containing several different feature types (that is, each shapefile contains measurement data such as temperature, pressure, etc). Is there a way to expose multiple layers from one shapefile, so that each feature type can be displayed? If so, how? Or do I need to re-configure my shapefile production to put each feature type into an individual shapefile?
This begs the question, how do you intend to get multiple layers out of one shapefile?
It's like a single table that you want to filter over some attribute?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
