[Geoserver-users] share geoserver's jar files with servlet
Hi
I have a small servlet that uses the Geotools libraries. Is there a way that I can use Geoserver’s Geotools jar-files with my servlet instead of copying all the Geotools stuff again on the server?
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
Ziegler Stefan ha scritto:
Hi
I have a small servlet that uses the Geotools libraries. Is there a way that I can use Geoserver's Geotools jar-files with my servlet instead of copying all the Geotools stuff again on the server?
Hum, yes, I believe you can put the .class file of your servlet in the
GeoServer WEB-INF/classes directory, declare and map your servlet
in the GeoServer web.xml, and be done with it.
We almost have a more pluggable way to do the same that would allow
you to build a jar instead and have it plug in into GeoServer, but
we first have to either get rid of the Struts UI.
Alternatively I believe you can already build a custom RESTlet as a jar
and have it plug in into GeoServer without needing to touch any
configuration file, but I'm not sure about the details, Justin and
David (cc'ed) know more.
Andrea Aime
OpenGeo - http://opengeo.org
